voltage regulator or alternator?, car not charging |
lostreasure |
Oct 3 2021, 06:39 AM
Newbie Group: Members Posts: 44 Joined: 24-June 13 From: new jersey Member No.: 16,048 Region Association: None |
Please help How do i determive which part to change- console gauge reads 10 amps and car is running horrible/pops/hesitates Thanks
DC_neun_vierzehn |
Oct 3 2021, 07:56 AM
Member Group: Members Posts: 415 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Spoke |
Oct 3 2021, 08:14 AM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Does the GEN light come on with key ON before starting the engine?
Does the GEN light go out with key ON and engine running? With engine running, measure all 3 wires from the alternator to the relay board with respect to chassis. Please report what you measure. Also measure the battery voltage too. |
windforfun |
Oct 3 2021, 06:38 PM
Senior Member Group: Members Posts: 1,878 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
13.4 V at battery while charging (IIRC). Your voltage regulator is probably shot.
VaccaRabite |
Oct 4 2021, 06:02 AM
En Garde! Group: Admin Posts: 13,471 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
First things first - put your battery on a charger and charge it back up. I'm amazed a battery with 10 volts will even start the car.
Zach |
Lo-Fi Version | Time is now: 24th June 2024 - 06:38 AM |
