nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,193 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Is the PMS setup the best value to mate a 3.0 engine to the 914 trans?
https://patrickmotorsports.com/collections/...clu901228ckspms |
roblav1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region ![]() |
Probably the best for a 9 bolt crankshaft. For a 6 bolt crank, the 901/914-6 flywheel with 1969 911S clutch.
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Is the PMS setup the best value to mate a 3.0 engine to the 914 trans? https://patrickmotorsports.com/collections/...clu901228ckspms That's what i started with on my 3.6, it should work just fine for a 3.0 (IMG:style_emoticons/default/idea.gif) |
SirAndy |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
I bought my kit from Kennedy Engineering. It came with the throw out bearing. Looks almost exactly the same otherwise. Idk the current price.
Mike D. |
OK, It runs now, and pretty good too! ![]() ![]() ![]() Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None ![]() ![]() |
QUOTE I bought my kit from Kennedy Engineering. It came with the throw out bearing. Looks almost exactly the same otherwise. Idk the current price. Me Too. But I can drive there and pick it up. I think it was a little less than that sale price, but not much... |
SirAndy |
I bought my kit from Kennedy Engineering. It came with the throw out bearing. Now that you mention it, i'm pretty sure i bought mine from KE as well. It included the TB but otherwise looks identical to the PMS kit. (IMG:style_emoticons/default/idea.gif) |
nditiz1 |
Cool thanks all!
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
There is another alternative.
Get the clutch assembly from a 2.2L 911, Vintage 70-71. It uses the 225mm 9 bolt flywheel and pull type pressure plate, but uses a different disk that mates with a 901. It will bolt on to every engine up to a 3.2 with nothing but factory parts. You have to use the 70-71 911 clutch arm, and you have to move the pivot point in the bellhousing. But the bonus is that you get rid of the pulley on the side of the transmission, and you no longer have any stress on the clutch tube. You can use a 76 911 clutch cable to hook it up. You will have to make a support for the back of the cable housing, but that is simple. The downside is the throwout bearing is over $300.00 these days. I know this works. I have it on the old 2.4 engine sitting on the floor of my garage. It works great, and it is all factory parts. Clay |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I bought my kit from Kennedy Engineering. It came with the throw out bearing. Now that you mention it, i'm pretty sure i bought mine from KE as well. It included the TB but otherwise looks identical to the PMS kit. (IMG:style_emoticons/default/idea.gif) PMS gets them from KEP. I bought my 3.2 conversion clutch and ring gear directly from KEP and saved a couple hundred dollars. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
DOOOH ! I just sold a completly freshened '70-'71 911 trans (pull type TOB) with a flipped diff. at Carlisle. Clay is right..... just about the easiest way to go using all Porsche parts. Would have been on the road with the 3.0 while I redo the 915/916 |
Gearup |
Member ![]() ![]() Group: Members Posts: 158 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None ![]() |
Try Stuttgart Muscle. Bot sure if they have the adapter for 3.0 to 901 but he makes a great product and cheaper than Kennedy and Others
targa72e |
Member ![]() ![]() Group: Members Posts: 263 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None ![]() ![]() |
[quote name='ClayPerrine' date='Nov 3 2021, 11:59 AM' post='2957333']
There is another alternative. Get the clutch assembly from a 2.2L 911, Vintage 70-71. It uses the 225mm 9 bolt flywheel and pull type pressure plate, but uses a different disk that mates with a 901. I don't think this is correct. The 2.0-2.7 ( and early turbos and Carreras with 3.0L) had a 6 bolt crank shaft. The 3.0SC-3.6 have a 9 bolt crank. Maybe you meant use the older clutch with the later 9 bolt flywheel? know this works. I have it on the old 2.4 engine sitting on the floor of my garage. It works great, and it is all factory parts A 2.4 would have a 6 bolt flywheel. john |
ClayPerrine |
[quote name='targa72e' date='Nov 3 2021, 04:14 PM' post='2957375']
[quote name='ClayPerrine' date='Nov 3 2021, 11:59 AM' post='2957333'] There is another alternative. Get the clutch assembly from a 2.2L 911, Vintage 70-71. It uses the 225mm 9 bolt flywheel and pull type pressure plate, but uses a different disk that mates with a 901. I don't think this is correct. The 2.0-2.7 ( and early turbos and Carreras with 3.0L) had a 6 bolt crank shaft. The 3.0SC-3.6 have a 9 bolt crank. Maybe you meant use the older clutch with the later 9 bolt flywheel? know this works. I have it on the old 2.4 engine sitting on the floor of my garage. It works great, and it is all factory parts A 2.4 would have a 6 bolt flywheel. john [/quote] Typo in my part sorry. But the fact is the 225mm pressure plate from a 71 911 will bolt onto a 9 bolt flywheel. |
nditiz1 |
Thanks again all.
I called up KEP and the lady said the have a 9 bolt fly wheel that can be used with the stock 914 clutch package. So I would get a new flywheel much like the one I have on the 2.7. The price is $360 and they estimated $40 to ship. So $400 is better than PMS. I can use the new 914 Sach clutch pkg off the 2.7 flywheel. Something she said on the phone was a little confusing. She said the clutch was 214mm, I thought it was 225mm for the 914. |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,380 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
Thanks again all. I called up KEP and the lady said the have a 9 bolt fly wheel that can be used with the stock 914 clutch package. So I would get a new flywheel much like the one I have on the 2.7. The price is $360 and they estimated $40 to ship. So $400 is better than PMS. I can use the new 914 Sach clutch pkg off the 2.7 flywheel. Something she said on the phone was a little confusing. She said the clutch was 214mm, I thought it was 225mm for the 914. My brother has that setup on his 3.0 to 901. Stage 1 kit. The disc is 228 mm from a vw bus I believe. Stock 914 disc is 215 MM , 911 is 215 to 71, then goes up to 225. |
nditiz1 |
Thanks Luke that cleared my confusion
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
markhoward |
Member ![]() ![]() Group: Members Posts: 379 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California ![]() ![]() |
Does anyone know the weight difference between the 215 and 225/228 MM setups?
Imagine the larger clutch can take more power. |
Krieger |
Does anyone know the weight difference between the 215 and 225/228 MM setups? Imagine the larger clutch can take more power. You can lighten the 3.0 flywheel and 914 ring adapter by a few pounds. I did this. I can let you know how much mine weighs when I get back. Of course it's a machinist and more $ @markhoward |
Lo-Fi Version | Time is now: 26th June 2024 - 05:04 AM |
