LeNeon |
Newbie ![]() Group: Members Posts: 1 Joined: 12-June 21 From: France Member No.: 25,627 Region Association: France ![]() |
Hello!
We're enjoying our 914 1.7, but a few issues have developed: - Our windshield wipers failed (yay, we'll have to remove the fuel tank...) - The heater had been (wrongly) restored, we'll see when we drop the tank - some localised rust... not too worrying though. But now we have a bigger issue, and we don't understand where it might come from. When accelerating under load, the car was "choking" at 3000 rpm. We adjusted the push-rods, as well as the injection a few hundreds of kilometres ago, it helped, but didn't solve the problem. Now, it's becoming really worrying, the car really hasn't any power. It's impossible to drive it, because the car just doesn't accelerate. When at idle though, the engine is fine, only a few hiccups. And when without load (wheels in the air), we can go through the gears and rev without any problems... Thanks in advance for your help! Peace |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,332 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
maybe transmission or clutch disc and clutch pressure plate? |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
Fuel filter clogged...
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,181 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Interesting. Pull a plug and have a look at it. Have you replaced the air filter (rat nest could cause a restriction)? Then I would start with double checking the timing (should be fine if you haven't messed with it.
Then look at the points while you are in there, those can cause issues like this. Coil can also cause stuff like that (but I would save that for later). You could check the dwell easily while looking at this other ignition related stuff. Check the fuel pressure (should be 29psi). If the timing and points and pressure look good then I would definitely check the fuel filter. Cheap but kind of a pain depending on where your pump and filter are. |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,984 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
wndsrfr |
mepstein |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,107 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
When the tank is empty, you can look down the fill hole with a flashlight and check the condition of the tank strainer/sock. Should be standing tall and not sucked flat. Also a good opportunity to look for rust/debris in the bottom of your tank.
burlybryan |
Member ![]() ![]() Group: Members Posts: 106 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None ![]() ![]() |
Also, since the heater was restored, which meant removing the fuel tank, it's possible a rubber fuel line is kinked. Happens a lot when re-installing the tank.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,994 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
It the car injected or carbureted?
--DD |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:05 PM |
