Turn signal switch removal |
partwerks |
Feb 14 2022, 07:09 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Can the turn signal switch part be removed from the wiper switch part?
I'm guessing that it just slides up on the four pins, but I don't want to just get rammy on it. Thought I should ask first. |
windforfun |
Feb 14 2022, 07:18 PM
Senior Member Group: Members Posts: 1,884 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Yes. They're independent.
partwerks |
Feb 15 2022, 08:44 PM
After removing it, one of the copper contacts has about an 1/8" hole rubbed through it on the high point. Is it still going to be usable?
windforfun |
Feb 16 2022, 10:40 AM
It's hard to say. It sounds like it's shot. Just remember not to tighten the four screws when you reassemble things. Those mechanisms need to "float" to work right. BTDT.
cholland_ |
Feb 16 2022, 12:18 PM
Newbie Group: Members Posts: 48 Joined: 11-October 06 From: Toronto, Ontario Member No.: 7,029 Region Association: None |
If it's shot, I replaced the switch on my '73 with this cheap Beetle part: https://www.cip1.ca/vwc-111-953-513-f/
It was a direct fit. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:04 AM |
