jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,332 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
My Busch is starting to sound like it’s gonna need replacing. Since the 1.8 version is NLA, I looking to the .914 World for possible replacement.
Prefer new and still in the box, or a good replacement. |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None ![]() ![]() |
This is about the only one I’ve seen for 1.8 HE’s:
https://www.rosepassion.com/en/p576636-sile...-bursch-P576636 I’ve been exhaust shopping till I’m exhausted lol… I still can’t make up my mind on how I want to proceed. |
Van B |
Also, FWIW, I’ve been in contact with Bursch trying to convince them to make a full system exhaust for the 914 so we can have some that doesn’t depend on that stupid flange location.
jim_hoyland |
Thanks for the Bursch info: I have forgotten what the flange is about ?
I just looked at Vintage Speeds SS muffler for the 1.8. https://store.vintagespeed.com.tw/914-2-0L-...stem-p180686506 Attached thumbnail(s) ![]() |
Van B |
I've just noticed a self-imposed design restriction with 914 exhaust. In 911's it's not uncommon to see full-system designs that don't rely on standard routing or transition points from the OE system. But for 914s, unless you want a race system, all mufflers are designed to mate to OE heat exchangers, and all heat exchangers are designed to mate to OE mufflers, and then you have to choose between a 1.7/1.8 flange and a 2.0 flange even though all aftermarket heat exchangers are using the same pipe diameter as the 1.8/2.0.
And then, with such an awesome long tube header from the factory, OE heat exchangers give torque away by not using equal length long tubes or collectors. This is the what makes the bursch so great. They are the ONLY ones to try and remedy some of those lazy oversights with their muffler. It really is the best muffler I've seen for the 914, period. but that's just my rant in your WTB thread lol... sorry. Van |
drem914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,034 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California ![]() ![]() |
This is about the only one I’ve seen for 1.8 HE’s: https://www.rosepassion.com/en/p576636-sile...-bursch-P576636 I’ve been exhaust shopping till I’m exhausted lol… I still can’t make up my mind on how I want to proceed. That version of ther Bursch is not for the 75-75 that Jim has. Those will fit the earlier dual twin pipe exit 70-74 not the dual single pipe HEs on the later 75-76 cars. This is the 75-75 version (currently not available) https://www.rosepassion.com/en/parts-porsch...h-3963-0-576638 |
jim_hoyland |
I have the earlier ‘74 (IMG:style_emoticons/default/smile.gif) version…. (IMG:style_emoticons/default/smile.gif)
See pic of Muffler to HE gasket Attached image(s) ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,102 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Get a recommendation for a local to you muffler shop that can weld up a new muffler for you. Match up the muffler dementions. Have them use the triangular bolt flanges. I imagine you'll be all in about 1/4-1/3 of that $843.59. PM sent.
drem914 |
I have the earlier ‘74 (IMG:style_emoticons/default/smile.gif) version…. (IMG:style_emoticons/default/smile.gif) See pic of Muffler to HE gasket I stand corrected |
jim_hoyland |
Get a recommendation for a local to you muffler shop that can weld up a new muffler for you. Match up the muffler dementions. Have them use the triangular bolt flanges. I imagine you'll be all in about 1/4-1/3 of that $843.59. PM sent. There is a good muffler place near by; I’ll stop by |
Lo-Fi Version | Time is now: 20th June 2024 - 05:22 AM |
