Highland |
Senior Member ![]() ![]() ![]() Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California ![]() |
My rear trunk latches and feels secure, but unlatches after a drive. I had this problem with a previous car and the solution was to change the pin. Is there a critical dimension on the pin I can file down? If the only solution is to get a new one, are the URO ones good? How do a tell if a used pin is good?
This is not my pin. Pulled it off the internet for communication purposes. ![]() |
eric9144 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California ![]() ![]() |
If your trunk is in the 'locked' position, does it also unlatch? If it's not the pin that comes down it could also be related to the locking mechanism as it has a pin that pushes the latch back to release the trunk.
Morph914 |
Member ![]() ![]() Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) with Eric, I would look at the locking mechanism.
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
If it turns out to be the latch pin, then just weld it up to make it bigger and file it back down to the original size.
Clay |
Lo-Fi Version | Time is now: 26th June 2024 - 12:21 AM |
