> Help identify 2.0 bus heads, 1.8 heads, Need extra eyeballs and brains
broomhandle
post May 4 2022, 02:31 PM
Hello,
clearing out some parts. I have what I remember and think are 2.0 bus heads, and 1.8 heads. Can somebody help confirm?
also.... I have a 2.0 block that I wanted to someda build a 2.0. I also have a set of 1.7 heads which I thought would be the best to convert. Anybody agree before I sell these?
2.0:
Replies(1 - 10)
broomhandle
2.0:
broomhandle
post May 4 2022, 02:37 PM
Sorry for the multiple posts. Images are 1mb ugh.
1.8
914Sixer
post May 4 2022, 04:56 PM
Not seeing any number stamps on the heads. Should be some 022/039 numbers
broomhandle
post May 4 2022, 05:12 PM
QUOTE(914Sixer @ May 4 2022, 02:56 PM) *
Not seeing any number stamps on the heads. Should be some 022 numbers
where would the numbers be located?
I found this, but still not helpful 2.0 bus vrs 2.0 914.
https://ratwell.com/technical/Heads.html
porschetub
post May 4 2022, 07:20 PM
QUOTE(broomhandle @ May 5 2022, 11:12 AM) *
They will be small valve US speced heads that were fitted to the bus ,not much good as they look in poor condition besides,best to move on with these as they aren't worth the machining required.
914sgofast2
post May 4 2022, 09:27 PM
2.0 heads from a 914 always have only three (3) studs to hold the intake manifolds to the heads. On VW buses, regardless of engine size, the bus heads always have four (4) studs to hold the intake manifolds to the head. The last picture looks like a 1.7 head from the shape of the combustion chamber. The first pictures you posted are difficult to identify because the combustion chambers look like someone has ground out an area to increase the size of the combustion chambers. We need to see the casting numbers on the heads, or know the valve sizes to ID the heads.
barefoot
post May 5 2022, 06:53 AM
Useful info for head P/N's:
https://web.archive.org/web/20130824065844/...nce/cylhead.htm
Barefoot
broomhandle
post May 5 2022, 09:36 AM
Thank you for the help, I have looked for casting numbers, and I do not see them. Where would they be located? Or my eyes are not as good as they were. (IMG:style_emoticons/default/smile.gif)
914Sixer
post May 5 2022, 04:48 PM
Here is where number stamping should be
Dave_Darling
post May 5 2022, 07:47 PM
914 Idiot
The Buses had small valves, the 1.8 valves are larger.
The "ratwell" and archived "tunacan" pages should list the valve sizes for the Bus and 1.8 heads.
--DD
- Lo-Fi Version Time is now: 25th April 2025 - 05:25 AM
