Front strut camber plate bushings |
L-Jet914 |
May 10 2022, 12:47 AM
Member Group: Members Posts: 254 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Curious if people here used the Elephant Racing front strut top camber plate bushing replacement $200 for rubber bushings (4 pieces and the metal sleeve) or just purchased 2 new camber plates from Porsche directly around 195 each. Prepping for suspension refresh. Front struts (Bilstein b6 insert), rear shocks (bilstein b6), lower control arm bushings (914Rubber), ball joints, turbo tie rods (Lemforder) etc.
914Sixer |
May 10 2022, 05:51 AM
914 Guru Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Never seen the top strut bearings wear out except from abuse. Street driving won"t cause bearing to fail unless you have alignment problems.
Lo-Fi Version | Time is now: 26th June 2024 - 02:57 AM |
