> Blinking Red Dash Light, Can’t find the reset button
jim_hoyland
post Jul 18 2022, 07:45 AM
Get that VIN ?
Bob and I bled the brakes Sunday and they work fine, fluid level is high. While bleeding the resivoir ran real low once.
Today, I just noticed the re light blinking even with the parking brake handle fully down. IIRC, there’s a reset button? But I don’t remember where it is.
Replies(1 - 12)
Jett
post Jul 18 2022, 07:50 AM
QUOTE(jim_hoyland @ Jul 18 2022, 06:45 AM) *
Try this: http://www.914world.com/bbs2/index.php?showtopic=293708
jim_hoyland
post Jul 18 2022, 08:07 AM
Get that VIN ?
Thanks for that link; I’ll look for that reset button.
NARP74
post Jul 18 2022, 09:40 AM
I have also had my parking brake button get flaky. With the brake handle in the up position, reach down and press the button several times and make sure the light goes on and off as it should.
jim_hoyland
post Jul 18 2022, 11:28 AM
Get that VIN ?
I turned the front wheels full right but didn’t see it; does the belly pan have to be removed 1st ?
Here’s a pic of what I’m looking for…..
troth
post Jul 18 2022, 11:35 AM
It should have a rubber cap over it.
emerygt350
post Jul 18 2022, 11:45 AM
It's visible through a small area where your tierod enters the wheel well. If I remember right...
jim_hoyland
post Jul 18 2022, 12:07 PM
Get that VIN ?
QUOTE(emerygt350 @ Jul 18 2022, 10:45 AM) *
So the pan doesn’t need removal ?
sportlicherFahrer
post Jul 18 2022, 12:20 PM
Nothing to see here.
Shouldn't. Depending on ride height you might not even need to jack the car up. Turn the wheels full lock to the right and you should be able to see the left side of the master cylinder just under the left tie rod. Sensor is on the left side of the master with the reset button sticking out of it. Mine was under a boot. My steering pan also had a hole directly under the sensor that made it easier to see/reach the reset button.
jim_hoyland
post Jul 18 2022, 01:14 PM
Get that VIN ?
Took the wheel off and found the rubber cap had to reach in with long needle nose plier to get it off.
Then I pushed the reset button.
Problem now is I don’t have enough room to reach in to put the wire and cap back on.
And, the bolts holding the pan on are frozen.
jim_hoyland
post Jul 18 2022, 02:05 PM
Get that VIN ?
Mission accomplished (IMG:style_emoticons/default/smile.gif) still gotta get the car on a lift to remove the belly pan bolts. And I like the idea of a hole to access the switch
post Jul 19 2022, 07:28 AM
Jim., I'm an hour and a half from you but your always welcome to use my lift. Just not this week. (IMG:style_emoticons/default/av-943.gif) I'll be at the WCR. (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland
post Jul 19 2022, 08:19 AM
Get that VIN ?
Thanks Kent; have a great WCR trip !
- Lo-Fi Version Time is now: 26th December 2024 - 05:21 AM
