> Oil Filler Assembly Plug Question, I didn't notice this part on the engine that's in my car
Highland
post Sep 23 2022, 01:03 PM
I just wanted to verify that the plug shown should be there. I know the engine I rebuilt doesn't currently have it. It's part #9 I think on the PET. The picture is off a spare block.
Also, does anyone know if the head vents are required for a PVC? Do the head vents intake air or relieve pressure?
Replies(1 - 5)
914Sixer
post Sep 23 2022, 01:25 PM
Vented heads require breather, Not certain that PVC be in the loop.
mgphoto
post Sep 23 2022, 02:31 PM
"If there is a mistake it will find me"
Breather ports on the heads are routed through a flashback valve then to the air cleaner, the PCV is connected directly from that port, which is open on some, closed like that one and modulated with a valve on others, eventually connected to the air cleaner.
Lockwodo
post Sep 23 2022, 03:06 PM
QUOTE(Highland @ Sep 23 2022, 12:03 PM) *
Part #9 and 13 are for one style of PCV valve. #9 is inserted from below the flange and #13 screws down onto it to clamp the valve in place. I had this style but replaced it with a PCV valve that just has a rubber grommet that the valve forces down into.
Highland
post Sep 23 2022, 03:50 PM
My mistake. Misread the PET. I'm referring to the black plastic plug in my picture. This plug was used to plug the PVC access hole.
Is this plug suppose to be there? I guess it's not on the PET.
Highland
post Sep 23 2022, 08:19 PM
Is the plug in the green square suppose to plug the PCV access hole circled in orange or should the PCV access hole be left open?
- Lo-Fi Version Time is now: 4th January 2025 - 10:55 PM
