Chevy Distributor Wire / points Question |
joea9146 |
Aug 9 2005, 08:22 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I have a 69 Chevy corvette that has a petroinix in place of points.
I no longer get spark and believe the Petronix has failed. I want to go back to the points but I am not sure of the wiring. The Petronix has a red and black wire going to plus and negative on the coil. I believe the points only require one wire going to (-) on the coil. Its been a while can someone confirm this ? |
flatout |
Aug 9 2005, 09:13 PM
Member Group: Members Posts: 239 Joined: 3-May 04 From: southeast missouri Member No.: 2,018 |
You are right.Your power source goes to the + side on the coil and the wire that comes out of the distr. from the points goes to the - side.Doesn't sound like you have forgotten anything! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) It's too bad about your Pertronix going bad,I really like those much better than points.
MecGen |
Aug 9 2005, 09:16 PM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
joea9146 |
Aug 10 2005, 05:32 AM
Once we get the car running I will order a new petronix.....
mrihop |
Aug 10 2005, 12:26 PM
Member Group: Members Posts: 265 Joined: 6-November 04 From: Pahrump, NV Member No.: 3,068 Region Association: None |
Did the points distributor have a resistor in front of it that never got bypassed when the Pertronix was installed???
Sammy |
Aug 10 2005, 12:54 PM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
Do you have room in there for a chebby HEI dizzy?
Reliable, cheap, and work really well even at high rpm if you get the aftermarket coil pack and stuff. |
Dr. Roger |
Aug 10 2005, 01:06 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Yea,
Just because there's no spark doesn't mean it's the spark trigger. IMHO id first check... Is the Petronix grounding out to something? Like inside the distributor? Are you using the same old coil? Is there a ballast resistor inline with the red wire going to the coil so you don't cook you coil... =-) You might ask, "Gee Roger, do I check that?" I would reply, "Test the voltage at the coil wire (red). You should read 6V to 8V." Saves coil. No resistor=cooked coil. Who know... =-) I only suggest to be safe.... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
MartyYeoman |
Aug 10 2005, 01:07 PM
Senior Member Group: Members Posts: 1,527 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
Lo-Fi Version | Time is now: 5th January 2025 - 03:09 AM |
