nivekdodge |
Member ![]() ![]() Group: Members Posts: 251 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region ![]() ![]() |
Like Bob Krantz, Powerplant in ....Powerplant out.Cha-Cha. I'm waiting for tranny parts and replaced the one pushrod seal that was leaking. The motor still has oil in it. Can i tilt it 10 degrees or so overnight to check for a leak?
Kevin |
nathanxnathan |
Member ![]() ![]() Group: Members Posts: 291 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California ![]() |
The motor will more likely leak when it's hot and running. The oil is thinner at temperature and quite a lot of oil goes from the head to the sump via the pushrod tubes. To check it when it's cold and not running isn't going to show you very much. ...if I am understanding what it is you're asking. With the trouble to remove rockers etc, I would opt to redo all the pushrod tube seals at once.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Won't be able to really check until it's running, but you will feel a positive engagement and DO -make sure you get the spring back in correctly. It's way softer than the push rods and will cut into them. So make sure it's not touching.
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,835 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Like Bob Krantz, Powerplant in ....Powerplant out.Cha-Cha. I'm waiting for tranny parts and replaced the one pushrod seal that was leaking. The motor still has oil in it. Can i tilt it 10 degrees or so overnight to check for a leak? Kevin Hey, I didn't mean to start a trend. |
nivekdodge |
Thanks guys,
Motor was just rebuilt and I know which one is leaking. Bob, I guess you really are my mentor! Kevin |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,214 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
The motor will more likely leak when it's hot and running. The oil is thinner at temperature and quite a lot of oil goes from the head to the sump via the pushrod tubes. To check it when it's cold and not running isn't going to show you very much. ...if I am understanding what it is you're asking. With the trouble to remove rockers etc, I would opt to redo all the pushrod tube seals at once. (IMG:style_emoticons/default/agree.gif) |
r_towle |
930cabman |
Thanks guys, Motor was just rebuilt and I know which one is leaking. Bob, I guess you really are my mentor! Kevin You can remove and replace the seals with the motor in the car. I recently did this and as I recall cylinders #1 or #2 were difficult |
r_towle |
You do not need to remove the tube from the engine to simply replace the seal. If you must remove the whole tube for replacement, you sadly will need to drop the engine.
Otherwise, remove rockers, pull tube and pushrod out far enough to replace seal, then install again. Rich |
nivekdodge |
I haven't tried this a second time but I am going to over the winter. I've red about polishing the mating surfaces and plan on that.
Bob Are yours still dry? Kevin |
bkrantz |
nivekdodge |
Superstitious like that huh?
Jack Standz |
Member ![]() ![]() Group: Members Posts: 295 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() |
You do not need to remove the tube from the engine to simply replace the seal. If you must remove the whole tube for replacement, you sadly will need to drop the engine. Otherwise, remove rockers, pull tube and pushrod out far enough to replace seal, then install again. Rich Not sure what you meant to say, but you do not need to remove the engine to replace the pushrod tubes or seals. |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,996 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
You do not need to remove the tube from the engine to simply replace the seal. If you must remove the whole tube for replacement, you sadly will need to drop the engine. Otherwise, remove rockers, pull tube and pushrod out far enough to replace seal, then install again. Rich Not sure what you meant to say, but you do not need to remove the engine to replace the pushrod tubes or seals. (IMG:style_emoticons/default/agree.gif) It’s not fun with the engine in the car, but it’s doable. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:31 AM |
