Free:MSD 6A & Tach adapter, ********Claimef********** |
jim_hoyland |
Jan 19 2023, 02:39 PM
Get that VIN ? Group: Members Posts: 9,593 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I removed the MSD after installing the 1-2-3 Ignition and it’s been sitting in a covered box since.
Attached image(s) |
bob164 |
Jan 19 2023, 03:36 PM
Member Group: Members Posts: 97 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
I will take the Jim, I can pick them up any time you like.
jim_hoyland |
Jan 19 2023, 04:28 PM
I will take the Jim, I can pick them up any time you like. You got it Bob (IMG:style_emoticons/default/smile.gif) |
bob164 |
Jan 19 2023, 04:46 PM
Thanks Jim, you're the best!
rhodyguy |
Jan 19 2023, 11:14 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,209 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
That setup works swell with a Unilite dist.
jim_hoyland |
Jan 20 2023, 09:02 AM
Jack Standz |
Jan 20 2023, 10:16 AM
Member Group: Members Posts: 440 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
If you hook up the Unilite backwards, you will quickly burn up the optical sensor/module. So, don't do that. And you might consider getting a spare module or two if you want to run the Unilite., while they're still available.
Also, the vacuum advance version of this distributor can fail in a way that might harm your motor. Probably best to only use the centrifugal advance version only. With that said, they really are awesome distributors, especially considering the time theywere originally designed. |
bob164 |
Jan 20 2023, 04:40 PM
Thanks all for the advice and insight. I will start looking into the spare sensor.
Lo-Fi Version | Time is now: 30th January 2025 - 12:03 AM |
