> A few 914-6 cases
Unobtanium-inc
post Feb 1 2023, 04:52 PM
Rob at DC just posted this, in case anyone is feeling lucky!
Replies(1 - 18)
post Feb 1 2023, 04:57 PM
Resident German
So close (IMG:style_emoticons/default/blink.gif)
Looking for 6404159 ...
Cairo94507
post Feb 1 2023, 05:19 PM
Michael
@SirAndy .... Man, that is so so so close. I would be tempted to try to buy that case just so you at least have an almost spot-on case and at least it is the period correct 914-6 case.
I have a '71 914-6 case that is about 20 numbers off my original case just to have a correct 914-6 '71 case in the event I ever sell the car or decide to do another engine. (IMG:style_emoticons/default/beerchug.gif)
rhodyguy
post Feb 1 2023, 05:24 PM
2 digits. I could pull the trigger on that one. If I needed a 6 case. Anyone inquire about pricing?
rick 918-S
post Feb 1 2023, 09:18 PM
Hey nice rack! -Celette
Close 4371
horizontally-opposed
post Feb 1 2023, 09:25 PM
QUOTE(Cairo94507 @ Feb 1 2023, 03:19 PM) *
zoomCat
post Feb 1 2023, 10:45 PM
QUOTE(rhodyguy @ Feb 1 2023, 06:24 PM) *
I believe they’re listed for $4k on the website.
https://www.dcauto.com/parts/78382?illustra...1&year=1970
gms
post Feb 5 2023, 10:10 AM
I will caution anyone thinking about doing business with DC Auto and Rob, their idea of a rebuildable motor is different then mine. In fact the only usable part my engines came with were the cases.
gms
post Feb 5 2023, 10:17 AM
after the engines arrived I immediately pulled them apart and here is what I found
cam tower so twisted the rocker arms were stick
The other cam tower was junk, both sides were Left cams still wet and rusty
gms
post Feb 5 2023, 10:21 AM
webers were seized and missing jets and jet holders
and the engine I paid an additional $500 for had a melted filter housing
GregAmy
post Feb 5 2023, 10:26 AM
When the point is to get the right case number so that you can burn into a $pendy concour$e re$to to sell your 914/6 to a big money collector for stoopit money...well, dem's the breaks...
Edit: after all, those engines were pulled from their original home for a reason: no one wanted them, most wanted to swap in a bigger engine. So it seems reasonable that they led a pretty ugly life...
gms
post Feb 5 2023, 10:31 AM
bearing surface scared
every cylinder was rusted but then sanded with about 120 grit sand paper to fit the pistons back in.
gms
post Feb 5 2023, 10:33 AM
I sent this to Rob and he sent me a set of 80 mm heads without valves and some useless pistons pistons
Engine 1
914/6 air cleaner- melted
Air cleaner snap cans – rusted thru
Weber IDA carbs – broken air correction screw, seized throttle shafts
Missing linkage cross bar, reverse lever and mounting brackets
Cam shafts pitted
Both cam towers – gouged cam bearing areas, second twisted
Oil Cooler – crushed & does not hold pressure
Heads (2.0 L1819d 911T) fly cut to 2.2L, inconsistent combustion chamber volumes, many studs missing
2.2L pistons and cylinders – water damaged, cylinders sanded
Missing 2 rear engine transmission mounting studs m10x105mm (999.062.099.02)
Engine 2
Only 1 K&N filter
Zenith cards - seized throttle shafts, incorrect for 914/6
Alternator ring cracked (fan and alternator acceptable)
fiberglass engine shroud - broken mounting holes, Incorrect version
Oil Cooler – AN? fitting welded to bottom
2.2L pistons and cylinders – mismatched set, water damaged, cylinders sanded
Oil pump - Seized
Missing flywheel
Missing 2 rear transmission mounting studs m10x105mm (999.062.099.02)
Cairo94507
post Feb 5 2023, 10:47 AM
Michael
Thanks for the heads-up about DC Auto and Rob. Finding trusted suppliers is always a gamble and anxiety ridden. I have been burned a couple of times while gathering parts for my car. Fortunately for me the parts I was burned on were not that expensive. (IMG:style_emoticons/default/beerchug.gif)
sixnotfour
post Feb 5 2023, 11:24 AM
I have 3 also ...Bare Cases
6414053
6404034
6405482
1k each offer..
Superhawk996
post Feb 5 2023, 11:36 AM
QUOTE(gms @ Feb 5 2023, 11:33 AM) *
Post to classifieds if you don’t want to deal with fixing them. I’m interested at the right price point that reflects need for machine work and a Total Overhaul.
Whatever you do, don’t scrap them!
Same on the plastic air cleaner assembly.
Unobtanium-inc
post Feb 5 2023, 09:11 PM
I've done well at DC, but I left with a truckload of cars.
davep
post Feb 6 2023, 08:44 AM
914 Historian
Adam, you had a better result due to ton's of experience and inspecting in person while making the purchase. Meanwhile Glenn got a pig in a poke.
Steve
post Feb 6 2023, 09:01 AM
QUOTE(davep @ Feb 6 2023, 06:44 AM) *
Its easier when you go and inspect the parts yourself. I've had good luck and bad luck with DC Auto. The last part i bought was a 911 front suspension bottom cover. It was rusted and banged up pretty bad. I threw it away and bought a new one for not much more money.
Also beware of LA Dismantler. I bought a motor from them and as soon as I got it home I did a leak down test and 3 of the 6 cylinders were really bad. They said I was not a "real" shop, so too bad. By the time I could get into a real shop, the warranty was gone. I should of did a leak down before pulling the exhaust and other stuff off of it. I would also recommend getting the warranty in writing and make them do a leak down in front of you.
- Lo-Fi Version Time is now: 15th January 2025 - 06:40 AM
