Cam Thrust bearing too tight, I've tried 3 sets |
Al Meredith |
Feb 18 2023, 05:58 PM
Senior Member Group: Members Posts: 969 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
The last couple of TY 4s I.ve built all have had a problem with the thrust cam Bearing. The side with the shoulders is always too tight. The cam will not spin freely . The other side , without the shoulders spins free. I 've tried three different brands and they have the same problem . The used ones have the gray finish warn but they spin fine. AL
rick 918-S |
Feb 18 2023, 06:04 PM
Hey nice rack! -Celette Group: Members Posts: 20,840 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Never toss out T4 stuff. Never know when the used parts are better than the new ones.
Geezer914 |
Feb 18 2023, 08:09 PM
Geezer914 Group: Members Posts: 1,819 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Single thrust or double thrust? Lay a sheet of 220 wet/dry sand paper on a sheet of glass. Put a few drops of oil on it and sand off a few thousands from the shoulder until you get close to the clearance you need. Polish the end with 400-600 grit.
Jack Standz |
Feb 19 2023, 01:21 AM
Member Group: Members Posts: 433 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
+1 Yep, just sand it, clean it, then install it.
930cabman |
Feb 20 2023, 10:09 AM
Advanced Member Group: Members Posts: 3,834 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
What cam are you running? As you know anything NOT spinning freely is never a good thing. I would be somewhat hesitant sanding the shoulders of the new cam bearings, but also not sure where else to go. Let us know of your results
rfinegan |
Feb 20 2023, 11:36 AM
Senior Member Group: Members Posts: 1,044 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
....don't forget the "tap a tap a" to seat the bearings after they get a light sanding
no video 1) lightly side one side of the cam thrust and try to fit in case half 2) rotate cam for bind or cam/ bearing lifting out of case 3) little sand opposite side and check fit 4) rotate come and check for bind in case 1/2 or cam /bearing lift out of case 5) once the cam is spinning and no longer lifting, use a brass or aluminum punch or wooden block and give the front of the cam 2-3 light taps to to seat the bearing. 6) repeat the 2-3 taps at the base end of the cam 7) measurements or about 0.002 is the goals for endshake of the camshaft 8) repeat above till the desired endplay in this 1/2 is achieve 9) repeat above on the other case 1/2 if using a double thrust ( a quick measure meant of the "good" thrust bearing will speed things up) 10) when assembling the case 1/2s together a final check of the end pay can be performed If I fit another set, i would fit the back side of the thrust bearing furthest from the gear, as the face closest to the gear will get the force from the angle cut gear I hope this helps |
rfinegan |
Feb 20 2023, 02:59 PM
Lo-Fi Version | Time is now: 15th January 2025 - 08:32 AM |
