Oil top cork gasket, Install Plain or bit of oil on it? |
StarBear |
Apr 14 2023, 03:21 PM
Senior Member Group: Members Posts: 1,950 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Finally getting around to replacing the original cork gasket under the oil filler neck.
Does it go on plain or with a light coat of oil like the oil filter and strainer? (IMG:style_emoticons/default/blink.gif) |
VaccaRabite |
Apr 14 2023, 03:28 PM
En Garde! Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Always did mine dry.
Zach |
StarBear |
Apr 14 2023, 04:01 PM
StarBear |
Apr 16 2023, 03:16 PM
Questions, as haven’t done this before:
1. How to remove that big metal clip holding the neck on - use two thumbs or two levers like screwdrivers? (IMG:style_emoticons/default/smile.gif) 2. I presume risk of 50-year old cork crumbles falling into oil reservoir? How best to prevent? (IMG:style_emoticons/default/beer.gif) Thanks! |
L-Jet914 |
Apr 16 2023, 03:20 PM
Member Group: Members Posts: 254 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Questions, as haven’t done this before: 1. How to remove that big metal clip holding the neck on - use two thumbs or two levers like screwdrivers? (IMG:style_emoticons/default/smile.gif) 2. I presume risk of 50-year old cork crumbles falling into oil reservoir? How best to prevent? (IMG:style_emoticons/default/beer.gif) Thanks! I just used a flat head screw driver to pop the retainer. Lifted straight up off the oil tower. Gasket slid right off for the most part. You could use a single edge razor blade to break the adhesion to the tower then remove the gasket if it's stuck on there. |
steuspeed |
Apr 16 2023, 07:31 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Questions, as haven’t done this before: 1. How to remove that big metal clip holding the neck on - use two thumbs or two levers like screwdrivers? (IMG:style_emoticons/default/smile.gif) 2. I presume risk of 50-year old cork crumbles falling into oil reservoir? How best to prevent? (IMG:style_emoticons/default/beer.gif) Thanks! It will be flat and baked to the top filler. |
StarBear |
Apr 17 2023, 12:44 PM
Questions, as haven’t done this before: 1. How to remove that big metal clip holding the neck on - use two thumbs or two levers like screwdrivers? (IMG:style_emoticons/default/smile.gif) 2. I presume risk of 50-year old cork crumbles falling into oil reservoir? How best to prevent? (IMG:style_emoticons/default/beer.gif) Thanks! It will be flat and baked to the top filler. Yep it was. Removed easily with spackling knife and in one piece. Done! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:07 PM |
