Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,474 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
What is the best way to remove the front brake caliper pistons from the calipers??? Thanks. (IMG:style_emoticons/default/popcorn[1].gif)
sportlicherFahrer |
Nothing to see here. ![]() ![]() ![]() Group: Members Posts: 1,089 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest ![]() ![]() |
About halfway down on PMB's tutorial page.
https://pmbperformance.com/pages/the-ultima...storation-guide |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,536 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
Small block of wood with folded rag over it to catch piston, then compressed air in bleeder.
Keep every thing covered so NO brake fluid flies out. |
steuspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest ![]() |
I had one stuck badly. Try a C-clamp to push it in first. I reconnected it to the brake line and clamp the other piston. Insert a rag to cushion the piston pop. Use the pedal pressure to free it.
Geezer914 |
Thanks for all the replies. Compressed air, PB blaster and a block of wood did the trick.
Lo-Fi Version | Time is now: 26th June 2024 - 09:35 AM |
