WTB: Patch Panel, Door sill area |
DahlbergDiver |
Apr 25 2023, 12:33 PM
Newbie Group: Members Posts: 10 Joined: 15-December 21 From: Michigan Member No.: 26,170 Region Association: Upper MidWest |
Need a patch panel for this area underneath the door on the passenger side. I don't know the proper name for it. I only need the outside part (no structural componenets) of it including the lip that holds the push-on inner door seal. I do not need any of the longitudinal attached. I have already replaced the entire longs.
Hopefully I'm describing it well enough. This area is completely gone in my car. It was toast and I cut out what was remaining of it to do the longitudinal replacement. Zip code is 49073. Am open to paying for shipping or meeting up. Attached image(s) |
friethmiller |
Apr 25 2023, 12:36 PM
Senior Member Group: Members Posts: 525 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Restoration Design sells it. It comes with the supports but you can give those away or hold onto them. Ya never know when/if you might end up purchasing a second 914. It happens (IMG:style_emoticons/default/biggrin.gif)
https://www.restoration-design.com/store/SRCH?Search=PP308 |
DahlbergDiver |
Apr 25 2023, 12:38 PM
I saw that, but it's only the flat section. I need the curved portions that go up the door pillars. About 6" high, front and back.
Does not need to be great condition. A little rust is fine. Just need something that will "work". |
friethmiller |
Apr 25 2023, 01:03 PM
I saw that, but it's only the flat section. I need the curved portions that go up the door pillars. About 6" high, front and back. Does not need to be great condition. A little rust is fine. Just need something that will "work". I'd likely patch it but I'd need to see the damage. Pictures? |
914werke |
Apr 25 2023, 01:19 PM
"I got blisters on me fingers" Group: Members Posts: 10,190 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I saw that, but it's only the flat section. I need the curved portions that go up the door pillars. About 6" high, front and back. Does not need to be great condition. A little rust is fine. Just need something that will "work". Those are also available PP353 L&R https://www.restoration-design.com/store/product/PP353R |
DahlbergDiver |
Apr 25 2023, 02:02 PM
Here is the best pic I have right now. The driver's side and passenger side were equally as bad. This was before my longitudinal replacement, of course.
Attached thumbnail(s) |
friethmiller |
Apr 25 2023, 04:45 PM
Thanks for the pic. That helps! Yeah, I'd buy the RD pieces plus the door hinge bottoms that they now offer. After that I'd bend/weld-in 18-20 gauge sheet metal to fill anything that's missing. You'll have it repaired and looking good in no time.
friethmiller |
Apr 25 2023, 04:55 PM
DahlbergDiver |
Apr 25 2023, 07:16 PM
Thank you. If I don't find a patch then that'll be the route I'll have to take. However, I am a cheapskate and I am patient, so if someone wants to save me a couple hundred bucks and cut this crusty section out of their parts car for me, I'll gladly pay good money for it. BTW "good money" is code for "less than $100 plus shipping".
partwerks |
Apr 26 2023, 05:20 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
PM sent.
Lo-Fi Version | Time is now: 26th June 2024 - 08:03 AM |
