akp2002 |
Member ![]() ![]() Group: Members Posts: 95 Joined: 11-January 21 From: Massachusetts Member No.: 25,059 Region Association: North East States ![]() ![]() |
The last owner removed the heater fan and I am reinstalling and can't find the wires that go from the Relay Board to the fan. Is this a separate cable and does anyone have an extra?
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,550 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
What year is your car? These wires changed locations over the years.
70-72, heater fan connects to the ignition harness. 73-76, heater fan connects to a double box connector emanating from the chassis harness near the relay board. |
akp2002 |
What year is your car? These wires changed locations over the years. 70-72, heater fan connects to the ignition harness. 73-76, heater fan connects to a double box connector emanating from the chassis harness near the relay board. Car is 1970. It should be a big brown connector and I can't see it any where near the distributor? |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
What year is your car? These wires changed locations over the years. 70-72, heater fan connects to the ignition harness. 73-76, heater fan connects to a double box connector emanating from the chassis harness near the relay board. Car is 1970. It should be a big brown connector and I can't see it any where near the distributor? It is on the other side of the engine compartment. I think it is two single connectors. |
JeffBowlsby |
See my first post above for the answer.
Lo-Fi Version | Time is now: 18th June 2024 - 05:57 AM |
