Petepat |
Member ![]() ![]() Group: Members Posts: 60 Joined: 1-December 19 From: Florida Member No.: 23,691 Region Association: None ![]() |
So I've got my speedometer out of my 72 914 and have opened it up. I need to get the needle off to get the faceplate off to fix the thing, the problem is trying to remove the needle, it's stuck solid or is there a simple way to remove it I don't know of? All suggestions welcomed.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,903 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
send it to Hartmut at palo alto speedometer
So I've got my speedometer out of my 72 914 and have opened it up. I need to get the needle off to get the faceplate off to fix the thing, the problem is trying to remove the needle, it's stuck solid or is there a simple way to remove it I don't know of? All suggestions welcomed. |
87m491 |
Member ![]() ![]() Group: Members Posts: 276 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States ![]() ![]() |
Generally it is a twist and pull for the older analog dials of this type. Of course you also have to immobilze the speedo shaft to affect this.
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Take small salad fork and lift up
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,547 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Pry upward with a plastic trim removal tool.
The plastic will keep you from marring the front face of the gauge. |
Petepat |
Thanks guys the salads fork did the trick!
Lo-Fi Version | Time is now: 20th June 2024 - 06:02 AM |
