| DennisV |
Sep 3 2023, 07:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Any tips on how to remove a stubborn front torsion bar? I soaked it in penetrating oil. Clamped onto the end with vice grips. Pounded it from the sides with a plastic mallet. That thing is in there. I got so frustrated, I dropped the entire front suspension to see if I could get a better attack off the car. Still stuck.
As far I as can tell, there is no way to access the other end to pound it out. Only wiggle and pull? ![]() |
| 914werke |
Sep 3 2023, 09:56 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,760 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
drive it forward our the front. Itll pop the caps off the front of the Arms but no biggie just clean & tap them back in place.
| Superhawk996 |
Sep 3 2023, 10:52 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,102 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
A couple places sell new end caps if the old ones get lost or damaged too much. Basically like a Welch plug. They have some curvature. By flattening them, it locks them into the torsion bar tube. |
| DennisV |
Sep 15 2023, 06:24 PM
I may be buying new a-arms and torsion bars. Today I'm back with the car. I tried:
I'm guessing if it is rusted in that bad, they both may be damaged beyond reasonable use. Anyone else faced this much resistance? |
| Superhawk996 |
Sep 16 2023, 12:46 AM
| DennisV |
Sep 16 2023, 07:00 PM
Lots of penatrant oil and propane torch. More of this. Better yet - MAPP gas or oxy-acetylene. Thanks for the encouragement. It finally freed up after drilling the cap off, liberal oxy-acetylene application and a lot of banging. (IMG:style_emoticons/default/smash.gif) Wow. That was a lot more effort than I expected. I really love the videos where people slide them out with two fingers! I was expecting the torsions bar to be ate up with rust. Surprisingly not. I'm still not clear why it was so froze up. |
| Superhawk996 |
Sep 16 2023, 10:16 PM
I'm still not clear why it was so froze up. Lots of surface area at the spline interface. Doesn’t take much corrosion on the splines to do a wonderful job of gluing parts together. A tiny corrosion ridge at the edge of the splines can also act like a wedge / stopper preventing the splines from sliding. The heat is needed to expand the LCA Inner Diameter more than the torsion bar Outer Diameter - allowing the parts to separate and slide free. (IMG:style_emoticons/default/smilie_pokal.gif) on the perseverance. When you reassemble - light coat of grease goes on the entire bar length (to prevent corrosion) but you want to be quite liberal with it at the splines. |
| iankarr |
Sep 17 2023, 02:50 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,607 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
When you reassemble - light coat of grease goes on the entire bar length (to prevent corrosion) but you want to be quite liberal with it at the splines. Definitely. Anti-seize works well on the splines also. You, too will be able to remove the bar with a few fingers. And then have to clean your fingers. |
| r_towle |
Sep 17 2023, 05:42 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Remove the a-arm from the car.
Stand it up on something with a hole in it Now use a BFH Use a good ball peen hammer as a punch Hit that with a sledge hammer. It will come out, if properly supported….one or two good hits will do it |
| bkrantz |
Sep 17 2023, 08:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Guys, get a hydraulic press, or friend with one, even the kind from Harbor Freight. It makes much 914 work MUCH easier.
| mepstein |
Sep 17 2023, 08:49 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,922 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Guys, get a hydraulic press, or friend with one, even the kind from Harbor Freight. It makes much 914 work MUCH easier. Good idea. (IMG:style_emoticons/default/beerchug.gif) |
| TheRuttmeister |
Feb 4 2025, 06:43 PM
Newbie ![]() Group: Members Posts: 42 Joined: 24-October 23 From: San Francisco Member No.: 27,680 Region Association: Northern California |
So I just did this a week ago and after basically trying ALL the various steps I want to summarize this (admittedly short) thread for those who follow.
(so they don't waste time like I did). drive it forward our the front. Itll pop the caps off the front of the Arms but no biggie just clean & tap them back in place. (IMG:style_emoticons/default/agree.gif) A couple places sell new end caps if the old ones get lost or damaged too much. Basically like a Welch plug. They have some curvature. By flattening them, it locks them into the torsion bar tube. Remove the a-arm from the car. Stand it up on something with a hole in it Now use a BFH Use a good ball peen hammer as a punch Hit that with a sledge hammer. It will come out, if properly supported….one or two good hits will do it Guys, get a hydraulic press, or friend with one, even the kind from Harbor Freight. It makes much 914 work MUCH easier. I'd recommend against using a ball-peen hammer or any kind of hardened tool. The torsion bar is hardened and wacking two hardened steel things against each other is a quick way to damage one of them, potentially quite badly. A brass or copper faced hammer is probably the best thing, but I don't actually own one. I used a piece of hardboard that lasted long enough (but only just). Also the flange that one of the rubber bushings rests against is perfect for holding the arm in a large vise, just put something on the floor so you don't drop the bar onto concrete or something. But yes, its just a pop-off plug at the front of the tube, wail on the bar and it will pop out the front. It feels a bit wrong, using the biggest hammer you have to smack the sh*t out of your suspension, but its the correct way to do it. Or go buy a cheap hydraulic press somewhere. Penetrating oil will help, but if you can't pull it out with minimal effort (you can slip a wrench around the narrow section of the bar and use that to lever it out) then just skip directly to big hammer time. The hammer makes it quick and easy. (apologies for thread necromancy! And thanks to the people who's advice I eventually took.) |
| brant |
Feb 5 2025, 03:31 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,278 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
as above...
I've had luck in the past driiving the bar in... which pops the cap off of the other end I've even had good success re-using the cap... swagging it back into place. brant |
| 930cabman |
Feb 5 2025, 03:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,853 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Lo-Fi Version | Time is now: 2nd October 2026 - 11:39 AM |
