> 1974 Headlight Switch pinout, 1974 Headlight Switch pinout
mgarrison
post Sep 16 2023, 12:16 PM
Hello,
I was hoping to reuse the light switch that was in my 74, but I am really struggling with the "current flow diagram" vs a typical "wiring diagram". The wiring diagram for the 71 is much easier for my addled brain to follow. However, the 71 used a different light switch with fewer connections, so not much help!
I no longer have popups, so I wont be using those connections, but hoping to use the connections for parking lights, headlights, and maybe the dimmer (knob twist) for the gauge lights.
Here's what I THINK I have ferreted out from the 74 current flow diagram in the service manuals:
Here's the best pic I could get of my light switch that shows most of the connection numbers (11 total connections):
I hoping someone can maybe confirm what I have so far as accurate, or even better share where each connections goes/it's purpose (IMG:style_emoticons/default/pray.gif)
Replies(1 - 5)
87m491
post Sep 17 2023, 01:01 PM
According to the current flow diagram,
30 is power to the headlight motors, K is power to instrument bulbs via the dimmer.
QUOTE(mgarrison @ Sep 16 2023, 10:16 AM) *
Hello,
JeffBowlsby
post Sep 17 2023, 03:14 PM
914 Wiring Harnesses
If it helps you here is a link to a Dash Switches circuit diagram on my harness website for the headlight switches. Various combinations of those connection tabs connect to different circuits dependent on what position the pull switch is in.
davep
post Sep 17 2023, 06:11 PM
914 Historian
K: illumination output for instruments. goes to fuse 7 input. often has a jumper for 58b but I replace with a wire from fuse 7 output so that the gauge lights are fused; several harnesses I have see had the jumper and other wires totally fried.
30: battery hot wire from fuse 10 input
30B: connected to 30 when switch is off, puts headlights in down position
58a: dimmer output for gauge illumination
58b: dimmer input; do yourself a favor and source from fuse 7 output
mgarrison
post Sep 18 2023, 08:05 AM
Thanks everyone - much appreciated! (IMG:style_emoticons/default/pray.gif)
mgarrison
post Sep 18 2023, 08:24 AM
QUOTE(JeffBowlsby @ Sep 17 2023, 02:14 PM) *
Your diagrams are a huge help! (IMG:style_emoticons/default/pray.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 05:44 PM
