DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 604 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
Did 914-6 engines have an engine lift bracket (aka hook or ring)? I have seen a bracket listed for some 911 engines, but perhaps that was only for later model years. I'm not finding a listing in the factory parts catalog. I realize it might not help much getting the engine in / out of the car, but it sure would be handy for getting it off the engine stand.
sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Don’t believe there is one. Recently disassembled mine and there wasn’t one.
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,779 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Don’t believe there is one. Recently disassembled mine and there wasn’t one. A handy thing to have for fitting engine to stand for sure,I attached chain to my one and a chain to the engine mount carrier with a spreader bar ,then used a chainblock to lift it ,all heavy duty as these are bloody heavy ,I think maybe they only came on the 911 motor as mine is ? but not a 100% on that. Certainly worth fitting one ,a request on WTB section should come up with one. (IMG:style_emoticons/default/beer.gif) . |
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
Don’t use a chain use a nylon 2” hd ratchet strap crisscross and lift from that easy peasy
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,789 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
porschetub |
Don’t use a chain use a nylon 2” hd ratchet strap crisscross and lift from that easy peasy Strange comment , I use rated chain and shackles ,chain isn't rapped around the motor ,spreader has even hanging points down to chains central to the eyelet and to lower point on mount front of the engine and simple to level by adjusting chain ,isn't that simple (IMG:style_emoticons/default/dry.gif) ?. Your method involves more work because you have to remove heat exchangers ,engine tins ,etc so you don't bend then inwards when the weight is that not less simple (IMG:style_emoticons/default/lol-2.gif) . Anyway what would I know as just an engineer of 32yrs (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/slap.gif) . Have a nice day (IMG:style_emoticons/default/beer.gif) . |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,962 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
My 6 has an eyelet on the flywheel end, it with a long 1/2" eye bolt through the engine mount on the other end.
EZ button |
Engineers are very smart
porschetub |
My 6 has an eyelet on the flywheel end, it with a long 1/2" eye bolt through the engine mount on the other end. EZ button Works good ,and real easy ,thanks , but still think it is only on rear of 911 motors ?, (IMG:style_emoticons/default/beer.gif) . |
930cabman |
My 6 has an eyelet on the flywheel end, it with a long 1/2" eye bolt through the engine mount on the other end. EZ button Works good ,and real easy ,thanks , but still think it is only on rear of 911 motors ?, (IMG:style_emoticons/default/beer.gif) . probably true, this motor came from a 1975 911. Engine builder went though it from top to bottom |
Optimusglen |
Senior Member ![]() ![]() ![]() Group: Members Posts: 922 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest ![]() ![]() |
Maybe it's just a 911 motor thing, on my 6 (from a 911T) I have the eyelet by the flywheel wnd, but used a big strap for the other end.
zoomCat |
Member ![]() ![]() Group: Members Posts: 197 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None ![]() ![]() |
Did 914-6 engines have an engine lift bracket (aka hook or ring)? I have seen a bracket listed for some 911 engines, but perhaps that was only for later model years. I'm not finding a listing in the factory parts catalog. I realize it might not help much getting the engine in / out of the car, but it sure would be handy for getting it off the engine stand. The PET doesn’t appear to show the lift bracket, but the shop manual does. ![]() Listed as item 52, called an ‘eye’. The engine won’t balance on it, you need something to lift from the other end. I’ve used nylon webbing, I’d consider an eyebolt through the engine mount somewhere. |
Lo-Fi Version | Time is now: 10th March 2025 - 04:34 PM |
