Horn pad restoration, Is center removable? |
jack20 |
Dec 19 2023, 10:32 AM
Member Group: Members Posts: 413 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Hello,
I have a horn pad that needs restoration. Is it possible to remove the vinyl covered center section with Porsche crest from the frame of the butterfly without damaging it? Thanks in advance. |
Mikey914 |
Dec 19 2023, 11:23 AM
The rubber man Group: Members Posts: 12,742 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Hello, I have a horn pad that needs restoration. Is it possible to remove the vinyl covered center section with Porsche crest from the frame of the butterfly without damaging it? Thanks in advance. It is, it has twisted tabs, so you have to push it off after the tabs are straight. |
914043 |
Dec 19 2023, 11:26 AM
Member Group: Members Posts: 93 Joined: 2-April 19 From: California Member No.: 23,007 Region Association: Central California |
Hello, I have a horn pad that needs restoration. Is it possible to remove the vinyl covered center section with Porsche crest from the frame of the butterfly without damaging it? Thanks in advance. if I remember correctly put a little downward pressure on the horn and twist to the left, if not to the right. (IMG:style_emoticons/default/smile.gif) |
dr914@autoatlanta.com |
Dec 19 2023, 11:30 AM
914 Guru Group: Members Posts: 8,113 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
it is glued to the metal frame, so can be carefully separated especially now that the 50 year old glue has dried!!!
Hello, I have a horn pad that needs restoration. Is it possible to remove the vinyl covered center section with Porsche crest from the frame of the butterfly without damaging it? Thanks in advance. |
jack20 |
Dec 19 2023, 11:52 AM
Hello, I have a horn pad that needs restoration. Is it possible to remove the vinyl covered center section with Porsche crest from the frame of the butterfly without damaging it? Thanks in advance. It is, it has twisted tabs, so you have to push it off after the tabs are straight. Thanks for the reply. Not seeing any tabs, Mark. Would they be in the embedded on the back side of the butterfly? |
jack20 |
Dec 19 2023, 11:53 AM
it is glued to the metal frame, so can be carefully separated especially now that the 50 year old glue has dried!!! Hello, I have a horn pad that needs restoration. Is it possible to remove the vinyl covered center section with Porsche crest from the frame of the butterfly without damaging it? Thanks in advance. Thank you George. Nothing else holding it in place as Mark mentioned? |
mepstein |
Dec 19 2023, 11:54 AM
914-6 GT in waiting Group: Members Posts: 19,679 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It’s just glued in. Use your fingers and pull it out. If you mess up, I have a nice one that you can have for the cost of shipping.
jack20 |
Dec 19 2023, 11:55 AM
Hello, I have a horn pad that needs restoration. Is it possible to remove the vinyl covered center section with Porsche crest from the frame of the butterfly without damaging it? Thanks in advance. if I remember correctly put a little downward pressure on the horn and twist to the left, if not to the right. (IMG:style_emoticons/default/smile.gif) Thanks for the reply. I have the butterfly off the wheel. Trying to remove the vinyl covered center portion of the butterfly. |
jack20 |
Dec 19 2023, 11:57 AM
friethmiller |
Dec 19 2023, 12:29 PM
Senior Member Group: Members Posts: 713 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
jack20 |
Dec 19 2023, 03:15 PM
Mikey914 |
Dec 19 2023, 05:11 PM
I'm sorry, went straight to the early horn "puck" when you mentioned this.
jack20 |
Dec 19 2023, 05:50 PM
jack20 |
Dec 19 2023, 06:39 PM
No apology needed Mark. You’ve been a huge help over the 10 years I’ve had this car.
It’s never had a stock steering wheel. I’m giving it one for Christmas! |
Lo-Fi Version | Time is now: 4th January 2025 - 10:41 PM |
