F/S drivers side door pockets in early and late black vinyl $65 each, Diferece is the grain on the vinyl no more soggy pocket! |
Mikey914 |
Dec 24 2023, 01:40 PM
The rubber man Group: Members Posts: 12,736 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The early is the wider grain vinyl like my 72 has. It is NOT the wider grain "Elephant " skin.
The later is the standard black late vinyl that most cats have. It does have an imperfection in the top lip was not cut properly, but it will not be noticeable once it's installed. These are $65 each+ actual shipping.. Will not be able to ship until the 30th. The late Attached thumbnail(s) |
Mikey914 |
Dec 24 2023, 01:44 PM
Early
Attached thumbnail(s) Attached image(s) |
Montreal914 |
Dec 26 2023, 08:19 AM
Senior Member Group: Members Posts: 1,701 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Hey Mark,
The third picture of the late one is the plastic only, or recovered with the vinyl? Grain seems different on that picture… (IMG:style_emoticons/default/confused24.gif) Are the holes pre-drilled in the plastic structure? Thanks. |
Mikey914 |
Dec 26 2023, 01:06 PM
1st group 3rd picture shows the base the late vinyl is applied to.
Has an area that was mis-cut. I wanted to point this out as with the vinyl attached you can't see it. The one screw in this area may or may not fully engage. However, the strap and the rest of the screws will hold it nicely. |
Mikey914 |
Dec 31 2023, 05:06 PM
Bump
Lo-Fi Version | Time is now: 25th November 2024 - 07:07 AM |
