Hard foam under carpet on PS at bulkhead? |
DC_neun_vierzehn |
Dec 25 2023, 02:20 PM
Member Group: Members Posts: 466 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
I have an early '73 2.0 with a build date 12/72.
I believe my 914 should have the molded hard foam under the carpet in the passenger side footwell at the bulkhead. I'm exploring the idea of putting a small subwoofer in that piece of foam. When I pull the carpet back in the footwell it's just the metal firewall. There's no foam there. Maybe it was removed at some point? In a parts lot I bought a while back, there was piece of hard molded foam that I assumed was for the footwell. However, when I pull the carpet back and try to put the foam there it does not seem to fit that space. Do I need to remove the speaker unit in that footwell and/or the center console to get this piece of foam in that space? Is that why it's not wanting to fit? Or do I have the wrong year foam? Is something else the issue? |
DC_neun_vierzehn |
Dec 25 2023, 02:23 PM
arbitrary |
Dec 25 2023, 03:07 PM
Member Group: Members Posts: 91 Joined: 25-April 21 From: UK Member No.: 25,475 Region Association: None |
It looks OK; you just need to try again to fit it. Here’s mine in place.
Attached thumbnail(s) |
FlacaProductions |
Dec 25 2023, 03:50 PM
Senior Member Group: Members Posts: 1,798 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Here's mine with the sub.
Thread here: http://www.914world.com/bbs2/index.php?s=&...t&p=2801031 and here: http://www.914world.com/bbs2/index.php?sho...p;#entry3045059 |
76-914 |
Dec 25 2023, 08:55 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,634 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
There is an early and a late version. I have both but I'm not sure which is which. (IMG:style_emoticons/default/lol-2.gif)
dtmehall |
Dec 25 2023, 09:28 PM
Member Group: Members Posts: 59 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
I have a 73, and have removed the speaker, and everything else in the passenger compartment.
I don't remember any foam |
barefoot |
Dec 26 2023, 08:38 AM
Senior Member Group: Members Posts: 1,327 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
There is an early and a late version. I have both but I'm not sure which is which. (IMG:style_emoticons/default/lol-2.gif) The 75 & 76 had a big cut-out on backside for a mileage counter for the cat converter to indicate service intervals. it was connected to a 2 part speedometer cable |
majkos1 |
Dec 27 2023, 08:25 AM
Member Group: Members Posts: 219 Joined: 11-August 17 From: Mile High 914 Member No.: 21,338 Region Association: Rocky Mountains |
There is an early and a late version. I have both but I'm not sure which is which. (IMG:style_emoticons/default/lol-2.gif) The 75 & 76 had a big cut-out on backside for a mileage counter for the cat converter to indicate service intervals. it was connected to a 2 part speedometer cable referred to as " Stash box" (IMG:style_emoticons/default/smoke.gif) remove gizmo, perfect hiding spot! (IMG:style_emoticons/default/shades.gif) |
Dave_Darling |
Dec 27 2023, 12:21 PM
914 Idiot Group: Members Posts: 15,059 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There originally wasn't a speaker in the footwell, just the one in the speaker pod to the side. If there's a speaker down in there now, it's not a surprise that the foam block doesn't fit.
--DD |
DC_neun_vierzehn |
Dec 28 2023, 01:12 PM
There originally wasn't a speaker in the footwell, just the one in the speaker pod to the side. If there's a speaker down in there now, it's not a surprise that the foam block doesn't fit. --DD The pod is the one I'm talking about. Just doing a test fit ... the foam does not want to fit in that space with the center console on the left and the speaker pod and heat hose behind it on the right. I suspect I need to pull all of the carpeting out in the footwell including behind the speaker pod and heat hose and it will fit if I do that. However, that means I need to remove the speaker pod and hose so that I can re-affix the carpeting properly when done. Just another seemingly simple 914 project that is actually a little bit more involved than what it appears at first blush. I'll take pics and share. |
JmuRiz |
Dec 28 2023, 03:47 PM
914 Guru Group: Members Posts: 5,504 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I still have mine attached to the OG carpet...not going to use either if you need a photo...I'm local-ish too.
DC_neun_vierzehn |
Dec 29 2023, 04:41 PM
I still have mine attached to the OG carpet...not going to use either if you need a photo...I'm local-ish too. @JmuRiz appreciate that kind offer, but I removed the speaker pod and all of the carpeting on the PS ... and the foam fit snug as a bug. I then moved on to cutting out a cavity for the sub like the one in this thread. I'm going to wait to hook it up until I have solved a couple of electrical gremlins (first things, first). Thanks again for the offer. |
rgalla9146 |
Dec 29 2023, 05:06 PM
Advanced Member Group: Members Posts: 4,649 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Aren't there three versions of the hard foam ? Early and late and late with EGR mileage counter ? |
DC_neun_vierzehn |
Dec 29 2023, 08:27 PM
Lo-Fi Version | Time is now: 22nd November 2024 - 03:14 AM |
