SOLD: 5 Lug Hubs and Stub Axles |
TOxner |
Jan 13 2024, 04:03 PM
I'm new here ... Group: Members Posts: 0 Joined: 26-October 17 From: Conway, AR Member No.: 21,546 Region Association: None |
This is a set of 5 lug hubs and stub axles for 4 bolt CV joints. They can be used to convert a 914 rear suspension to 5 lug. $200 plus shipping. Thanks.
aturboman |
Jan 13 2024, 06:20 PM
Member Group: Members Posts: 136 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
Can you confirm the stub axles have 27 splines and are 110mm at the OD. If so I would like to buy this set.
Thanks |
TOxner |
Jan 14 2024, 07:59 PM
The axles are 110 MM OD, but they are 28 spline. Thanks,
Tom |
TOxner |
Jan 15 2024, 01:35 PM
The hubs and stub axles are SOLD. Thanks.
Tom |
808 WRX |
Jan 16 2024, 12:14 PM
Member Group: Members Posts: 59 Joined: 4-June 20 From: San Jose, CA Member No.: 24,349 Region Association: Northern California |
jim_hoyland |
Jan 16 2024, 02:16 PM
Get that VIN ? Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Are 38 splined for 914 or 911 ?
aturboman |
Jan 16 2024, 03:09 PM
This whole transaction has left me a bit unhappy. I wanted the parts and made that clear in the first post. 3 days no info then suddenly they are sold to another person who clearly ins't sure either if he actually bought the parts.
Not a great way to join the community. I've moved on but believe a reassessment of selling practices is in order here. |
808 WRX |
Jan 16 2024, 03:24 PM
@aturboman
Sorry, I didn't mean to cut in front of you. Your post said you wanted them if they were 27 spline. He said they weren't 27 spline so I jumped on them. Can you confirm the stub axles have 27 splines and are 110mm at the OD. If so I would like to buy this set. Thanks |
aturboman |
Jan 17 2024, 02:42 PM
The coarse spline denotes 911 based parts vs the VW finer spline parts. That was what I was trying to determine. I'm sure it was a simple miscount.
Appreciate your post but no worries at all, its all on the seller. I hope the parts work out for your project. Thanks @aturboman Sorry, I didn't mean to cut in front of you. Your post said you wanted them if they were 27 spline. He said they weren't 27 spline so I jumped on them. Can you confirm the stub axles have 27 splines and are 110mm at the OD. If so I would like to buy this set. Thanks |
Lo-Fi Version | Time is now: 25th June 2024 - 11:13 PM |
