RAX914 |
Member ![]() ![]() Group: Members Posts: 109 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None ![]() ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,104 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
MAKE SURE is for 7mm arm or has adapter. Most stuff sold now has 9mm slot. Blades WILL flop around.
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,893 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
Good call, Mark - it says "certain blade lengths" - would be great if it had the 7mm adapter.
From the listing: Quick and easy installation Arm types covered (certain blade lengths only): Bayonet (7mm) Pin blade Hook (8mm) Hook (7mm) Hook (Audi) Hook (9x4) Hook (9x3) Pin arm (6.35mm) Pin arm (4.8mm) |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
Pelican has that same p/n listed for $6.72, description says 'fits 9mm arm'.
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,860 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I would look around for silicone blades if trey are available.
Lo-Fi Version | Time is now: 31st March 2025 - 11:07 AM |
