930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,214 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Somewhat getting my a** kicked trying to get a conversion completed. We have a decent chassis and a fresh 2.7 that has made the rounds from Ollies and Eksten's. Still running a small business and often prioritize kids/grandkids when it comes to free time. It is coming up on two years and currently attempting to work through oil lines, exhaust, do I need an external cooler or not??
All the guys who have done them, would you do it again? |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Absolutely!
Attached image(s) ![]() |
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,193 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
I would definitely do it again, if I have a good running 6 to put in.
Weld the mount Cut holes for tank Install engine Slight wiring Enjoy! I was planning to put a front cooler in my 2.4 due to it getting hot. |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,535 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
mate914 |
Matt ![]() ![]() ![]() Group: Members Posts: 762 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States ![]() ![]() |
Somewhat getting my a** kicked trying to get a conversion completed. We have a decent chassis and a fresh 2.7 that has made the rounds from Ollies and Eksten's. Still running a small business and often prioritize kids/grandkids when it comes to free time. It is coming up on two years and currently attempting to work through oil lines, exhaust, do I need an external cooler or not?? All the guys who have done them, would you do it again? You are far north. If the engine is bone stock and not taken to the Glenn. I would drive it. You might be able to get away with a Setrab and fan under rear trunk. The 9146 project I'm on has been 4 years plus, and almost finished. Spending time with your kids and grand kids is more important than any 914.... Matt (IMG:style_emoticons/default/flag.gif) |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,380 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
Hi John,
Having done 3 conversions and worked on a few org 6's in the past. I'd have to say yes I'd do it again. I may not be working as fast now a days but I'd do another 6 conv. I may do one with my son here in a few years. Just need to find the right chassis for it as I have several 6 parts on hand. With that said, what issues are you having with on the oil system? A 2.7 should have a front oil cooler. The exhaust is pretty straight forward. I'm actually working on getting my brothers 3.0 conv front oil cooler setup mocked up and installed here sometime this spring. LMK if I can help. |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,858 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Absolutely! Even though my car is an original 6, it really doesn't matter once that engine is out. We are just getting started on a swap from the 3.2 with Motronic injection to a '95 3.6 out of a 993. The driving experience with the 3.2 was crazy; I can't wait to drive it with the 3.6.
Regardless of your 6 engine size, I would still add an external oil cooler/thermostat. I have had had a few variations of coolers over the decades on 3 different original 6 cars: 1. 2 VW 411 coolers, 1 behind each foglight grill with a thermostat in the engine compartment on the firewall. We had flexible SS line run uo the driver side long, behind the rocker to connect it all up and we vented it out the inner wheel well. Worked quite well, but I lost my foglight. As you can see, it was very crude, it was 1984, and these cars were really not worth a lot. ![]() 2. On my current 6, it came to me with 1/2" copper pipe plumbed and soldered from the engine all the way to the front, behind the passenger side rocker and across the nose and ball again- think large trombone style and that worked well- or so I was told by the former owner. ![]() 3. My current, and favorite set-up, is using a set of GT hard lines up the driver side long that terminate just inside the driver footwell. Then I have a rubber hose with AN fittings that go from there to inside the frunk and connect to a Setrab oil cooler mounted across the nose. Currently, the thermostat is mounted in the trunk but that is being relocated to where I believe it should be located, on the engine firewall to the right of the motor mount. That is what I had with the 3.2 and it worked fine. I did have the GT opening in my bumper as well as valance. But I did not cut the nose open- we just pulled the 5 rubber plugs out of the nose panel rot allow air to flow. ![]() 4. We are now going to replace that Setrab cooler with a larger cooler, about 1" taller and 3" wider and a slosh thicker. We will add 3 4" fans right on the backside of the cooler to pull air through the cooler and we will then have an aluminum shroud that covers and seals all of that, venting it out the louvered floor of the trunk. Anyway, hopefully that gives you a few ideas. Cheers, Michael (IMG:style_emoticons/default/beerchug.gif) |
914Toy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 722 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California ![]() ![]() |
Absolutely! My 2.7 with Weber carbs and SC cam grind, plus Clewett crank fire, transformed the car. I recommend a front oil cooler for total peace of mind.
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,994 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Hold tight - might be a nice real /6 with a 2.7L coming up for sale soon. (IMG:style_emoticons/default/cool_shades.gif)
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Front cooler
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Heck yes I would do it over 100 times. I run a front cooler even with my 2.4 just because
930cabman |
Hold tight - might be a nice real /6 with a 2.7L coming up for sale soon. (IMG:style_emoticons/default/cool_shades.gif) Needs a few odds and ends |
mlindner |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Definitely worth it. I bought my 75 914 back in 86 with immediate plans to convert it to a six. I bought a used 1974 2.7 with a top end overhaul. Bought new PMO webers back then $1k with everything. Headers, motor mount and muffler from MSDS. I tried to run it without an external oil cooler in California but it ran too hot, so I bought a setrab cooler from PMS and the shroud from Getty. Very simple conversion. Back date the flywheel to a 2.0 six flywheel and MB911 and others sell aftermarket tin, oil tanks and mounts. I did it in my garage with a Haynes manual, floor jack and jack stands. In 2000 I switched to a stock 3.2 and now I’m upgrading to a 3.6. Lots of pro’s and con’s, but the 2.7 with webers works the best with a stock geared trans for a street and occasional auto cross car.
930cabman |
Sounds near unanimous, thank you all and I guess keep the course is the answer. Being in the Northeast I will run her for a while without an external(front) oil cooler. I have seen the oil thermostats are labeled as 180 degrees. Don't we want closer to 210 - 220 oil temps?
Currently fitting the Goodridge ends to the SST flex hose is kicking my a**. I ordered the tool from Pegasus earlier to assist with this operation. Is there a magic crows foot to reach the -16 fitting on the bottom of the oil tank in the fenderwell? |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Sounds near unanimous, thank you all and I guess keep the course is the answer. Being in the Northeast I will run her for a while without an external(front) oil cooler. I have seen the oil thermostats are labeled as 180 degrees. Don't we want closer to 210 - 220 oil temps? Currently fitting the Goodridge ends to the SST flex hose is kicking my a**. I ordered the tool from Pegasus earlier to assist with this operation. Is there a magic crows foot to reach the -16 fitting on the bottom of the oil tank in the fenderwell? I find it’s better to attach the hose to the bottom of the tank and then slide it into place. It sort of rolls in. |
Superhawk996 |
Don't we want closer to 210 - 220 oil temps? Yes ^ 10 I wish this internet mythology of 180 degree oil would go away but I accept that it will continue forever. There’s hardly a modern car running oil at 180F under load, and both the oil, and engines last much longer than they ever have. This isn’t a coincidence. Likewise don’t let people fool you that air cooled is different. Air cooled motorcycles and cars have always run hotter oil than water pumpers. Oil doesn’t magically disintegrate at 250F as some would have you believe. |
mate914 |
Sounds near unanimous, thank you all and I guess keep the course is the answer. Being in the Northeast I will run her for a while without an external(front) oil cooler. I have seen the oil thermostats are labeled as 180 degrees. Don't we want closer to 210 - 220 oil temps? Currently fitting the Goodridge ends to the SST flex hose is kicking my a**. I ordered the tool from Pegasus earlier to assist with this operation. Is there a magic crows foot to reach the -16 fitting on the bottom of the oil tank in the fenderwell? Running the fan with right sized pulleys and heat block off plates on engine both help with cooling. 2.7's do run on the hotter size. I have a 2.7 with mod S cams and j&E pistons getting ready for the street. We are running the Taormina racing oil block off with oil cooler up front. The oil line fitting kit from Pegasus helps a lot. Here to help. Matt |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
worn |
My cooler is beside the transmission. I want the frunk space. Uses a pair of fans. Since I like to cover distances I also added taller fourth and fifth gears. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:27 AM |
