> Time for a new fresh air fan, This one’s kaput
76-914
post Feb 26 2024, 02:14 PM
Now I know why my fresh air fan wouldn’t work! Apparently it got so hot. The brush melted off of its connection point.
Replies(1 - 6)
DRPHIL914
post Feb 27 2024, 06:56 AM
Dr. Phil
QUOTE(76-914 @ Feb 26 2024, 03:14 PM) *
wow, that must have been stuck , causing overload. was it clogged with debris? Mine was.
when i replaced mine i ordered a whole new fan/motor assembly from URO and its still going strong, i had no idea that these little fans could push that much air on the high setting!. , along with the seal kit from 914rubber its all better than new now.
914Sixer
post Feb 27 2024, 07:01 AM
URO fan assemblies are around $100 depending where you shop.
DRPHIL914
post Feb 27 2024, 07:04 AM
Dr. Phil
QUOTE(914Sixer @ Feb 27 2024, 08:01 AM) *
i have not checked recently , when i did mine 2 years ago they were about $80 then. Ims surprised they are not more than $100 with how everything has gone up in the last 2 years.
I looked at just doing the motor but not worth the time and trouble when a good assembly is available.
post Feb 27 2024, 09:36 AM
Phil, I perused your thread before I jumped in on this. Just like you, I had pretty much "buttoned up" everything when I noticed that my fan (which previously worked) was now kaput. No debris but the fan was stiff to turn so I suspect that was the nail in the coffin. Next I decided that I too had better check my WW's. They work but the squirter motor is kicking on. I'll check that today. I ordered the URO fan yesterday from carports.com. They're $80; $90 w/shipping & tax. Well worth it IMHO. They ranged from $150 on down depending upon the seller. A few m months back installed the 914rubber kit so to say I was a little pissed I hadn't checked the fan operation at that time would be an understatement. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/av-943.gif)
bdstone914
post Feb 27 2024, 01:30 PM
bdstone914
@76-914
Kent,
Be sure to test all three speeds on the motor before installing. I tested a motor with direct power to it only to find the resistor pack bad after installation.
Bruce
post Feb 27 2024, 07:20 PM
QUOTE(bdstone914 @ Feb 27 2024, 11:30 AM) *
@76-914
Kent,
Bruce
Good point. Thx.
- Lo-Fi Version Time is now: 7th September 2024 - 08:53 PM
