BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,273 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
So i have an aim dash in my race car with oil pressure and temp gauges in the usual 6 cylinder engine locations on the engine and tied into the pdm/aim logger. I also have a gorgeous set of traditional gauges i would like to put back in as my primary with the aim dash to the side for alarms and times etc. Where else can i tap into for the analogue sensors to get BOTH to work accurately at the same time? Mechanic telling me that using chain box lines will not read as accurately as standard locations. Anyone try this?
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,468 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Your mechanic is correct. If you try to wire both sets of gauges up to the same sensors then it will likely affect the voltages and amps and cause incorrect readings.
If the sensors are simply voltage outputs then you MIGHT get away with running both gauges in parallel. Give it a shot, see what happens. But if they're impedance sensors then that won't work. I run the stock tach in the stock location to stay historics-looking, but I use my small Race Technology dash put off to the side for gauging, warnings, data acq, and engine logging. |
Lo-Fi Version | Time is now: 2nd April 2025 - 02:37 AM |
