pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
Looking for GT oil cooler shroud(or kit), and a flywheel with ring gear for a 2.0t motor to mate to a 914 901
open to suggestions as well |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,465 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
http://www.914world.com/bbs2/index.php?s=&...t&p=3082851
Sold the flywheel but still have the ring gear nos friction disc & pressure plate(s) (IMG:style_emoticons/default/bye1.gif) |
live free & drive |
Member ![]() ![]() Group: Members Posts: 168 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None ![]() ![]() |
I have to sell an unused Patrick Motorsports lightweight flywheel (225mm, 6 bolt), assuming the 2.0T is for a six. I'll throw in for free a new high performance clutch disc if you want it too. PM me if interested
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,669 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
He's looking for a 914-6 flywheel that is also used for the 2.0 911 six. Unless he is using the rare 71 specific 901 that uses a 225mm pull clutch. The 215mm flywheel works with a 914/901 trans. https://www.ebay.com/itm/266697618929?itmme...%3ABFBM5sOCrYBk
This is a 215mm flywheel that works with 6 bolt 911 cranks (2.0-2.7). This is what I used with my 2.7 and had no slipping issues with a stock 2.0 pressure plate and disk. Getty Design sells the two piece shroud. http://gettydesign.com/category/914/coachwork/ Patrick Motor sports sells a complete shroud kit with oil cooler. |
pete-stevers |
Thanks Steve!
Lo-Fi Version | Time is now: 7th September 2024 - 08:30 PM |
