Chuckbizkits |
Newbie ![]() Group: Members Posts: 3 Joined: 28-February 22 From: North OC CA Member No.: 26,362 Region Association: Southwest Region ![]() |
I am doing an LS3 swap. I've gutted all of the wiring and rewiring everything from scratch. I do want to retain the original style ignition switch. I'm having trouble identifying some of the ignition switch pigtail wires. The big red wire is BAT+ in. The medium red wire is accy run (off on start). The yellow wire is start. The grey wire is 12 v while off. Which wire is ignition run? I have a black wire, a small red wire and a grey striped wire left. Thanks for your help.
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,644 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Chuckbizkits |
Sorry Jeff. This is out of my league. Which wire from the pigtail is hot at start and run? |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
My switch:
Attached image(s) ![]() |
Chuckbizkits |
Lo-Fi Version | Time is now: 7th September 2024 - 05:53 PM |
