FS: More bling |
FS: More bling |
Montreal914 |
Jun 22 2024, 01:06 PM
Senior Member Group: Members Posts: 1,603 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
For Sale:
Freshly replated parts. Prices include shipping to the lower 48 states: Rear mounted fuel pump brackets (3 available): $25 ea. The one on the right had the nut epoxied in place for some reason (IMG:style_emoticons/default/confused24.gif) $20 The one on the right (epoxied) Engine lid latch: $40 Parking brake short cable and parts: $20 (note condition (IMG:style_emoticons/default/dry.gif)) |
bdstone914 |
Jun 22 2024, 07:21 PM
bdstone914 Group: Members Posts: 4,560 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The brackets you list as fuel pump are actually for the coil. They are very similar but the ears of the fuel pump brackets slant downward.
Montreal914 |
Jun 22 2024, 07:29 PM
Bruce ( @bdstone914 ) , I am not so sure about that...
These were removed from fuel pump assembly. You can see the semi-circular notch on the top of the omega which is there to clear the fuel pump connector. The coil bracket doesn't have the circular notch. Edit: This is what I am referring to. I may be wrong, but I don't see any pictures of coil brackets with that notch. That being said, this bracket could probably be used for either (pump or coil). Get two for $40 shipped! (IMG:style_emoticons/default/biggrin.gif) |
bdstone914 |
Jun 22 2024, 11:32 PM
Bruce ( @bdstone914 ) , I am not so sure about that... These were removed from fuel pump assembly. You can see the semi-circular notch on the top of the omega which is there to clear the fuel pump connector. The coil bracket doesn't have the circular notch. Edit: This is what I am referring to. I may be wrong, but I don't see any pictures of coil brackets with that notch. That being said, this bracket could probably be used for either (pump or coil). Get two for $40 shipped! (IMG:style_emoticons/default/biggrin.gif) You could be right. I have a couple coils with the brackets still on them. I wll see if they have that notch which i can't see that it serves a purpose. But if i am right that notch would provide clearance for the round connector housing. |
s13u74cr4 |
Jun 23 2024, 03:50 PM
Newbie Group: Members Posts: 4 Joined: 2-September 23 From: PNW Member No.: 27,558 Region Association: Pacific Northwest |
Gonna say I am pretty sure those are fuel pump brackets. After so recently futzing around with my lines that bracket is keenly in my memory. The cut out bit is indeed where the electrical harness fits. The PO of mine had flipped this bracket so it was nearly impossible to get the lines and pump to fit without binding, or that is just correct which is not ideal. I flipped it which made that problem go away. Meaning indentation facing rearward not back to the firewall.
Lo-Fi Version | Time is now: 30th June 2024 - 03:31 AM |
