912E hosts "critters" |
dr914@autoatlanta.com |
Jul 10 2024, 12:15 PM
914 Guru Group: Members Posts: 8,043 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Jul 10 2024, 12:16 PM
Superhawk996 |
Jul 10 2024, 01:30 PM
914 Guru Group: Members Posts: 6,464 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Not unique to 912’s
Seen it on Bugs, 914s, and 911 engines. I’ve even seen it on lawn equipment. Pretty much anything air cooled with a shroud. This is why I always advise someone buying a used engine that’s been sitting to at least remove the tin and see what’s hiding in there. I’ve found tools, spark plug insulators, cigarette bits, etc. makes you go (IMG:style_emoticons/default/idea.gif) |
windforfun |
Jul 10 2024, 02:54 PM
Senior Member Group: Members Posts: 1,937 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Not unique to 912’s Seen it on Bugs, 914s, and 911 engines. I’ve even seen it on lawn equipment. Pretty much anything air cooled with a shroud. This is why I always advise someone buying a used engine that’s been sitting to at least remove the tin and see what’s hiding in there. I’ve found tools, spark plug insulators, cigarette bits, etc. makes you go (IMG:style_emoticons/default/idea.gif) Find any Rolex watches? |
nditiz1 |
Jul 10 2024, 05:05 PM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I did not find that in my 912e, but did in this 3.0 I picked up recently. As Phil said not 912e specific.
Shamless plug while on the topic of 912e, my bastard backdate is for sale (IMG:style_emoticons/default/beer3.gif) |
burton73 |
Jul 10 2024, 05:36 PM
burton73 Group: Members Posts: 3,646 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I did not find that in my 912e, but did in this 3.0 I picked up recently. As Phil said not 912e specific. Shamless plug while on the topic of 912e, my bastard backdate is for sale (IMG:style_emoticons/default/beer3.gif) I thought your 912 E was sold a while ago. The brown one? Best Bob B |
technicalninja |
Jul 10 2024, 06:30 PM
Senior Member Group: Members Posts: 1,821 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I've got WORSE!
If you turn your car off in "fresh air" versus "Recirculation" you leave a HUGE hole open into the HVAC system. Most modern cars have a horizontal down draft cabin air filter which makes a "Jim Dandy" nesting surface for rodents. They have their litter of mini rodents on TOP of the air filter which they chew on... You jump in your car and suck those puppies into the blower motor. They DIE! And then they leak! And your car smells like a carcass a few days later... I charge MORE if I'm violently retching during the repairs. Wiping the resultant "scum layer" out of the blower motor housing is a job I'd rather never do again! |
bkrantz |
Jul 10 2024, 07:13 PM
914 Guru Group: Members Posts: 8,042 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Need more of these.
Attached image(s) |
nditiz1 |
Jul 10 2024, 09:07 PM
Jack Standz |
Jul 11 2024, 07:38 AM
Member Group: Members Posts: 361 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
wonkipop |
Jul 11 2024, 08:26 AM
Advanced Member Group: Members Posts: 4,594 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Jul 11 2024, 09:43 AM
Root_Werks |
Jul 11 2024, 11:52 AM
Village Idiot Group: Members Posts: 8,414 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Little critters can really get up almost anywhere. Little hangar trick a buddy taught me years ago was using cheap party strobe lights in the hangar/shop. Something about the flashing lights really bug rodents, birds etc. Never had any, so guessing it works.
campbellcj |
Jul 11 2024, 12:35 PM
I can't Re Member Group: Members Posts: 4,567 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I live in a very critter-dense area and it's a constant battle. This thing is literally in my backyard:
https://en.wikipedia.org/wiki/Wallis_Annenb...ldlife_Crossing Not long ago a mouse/rat chewed wiring on my 911 which was $$$$ but thank goodness, they didn't get inside the car. Luckily as far as I know they've left my 914 alone maybe because the newer cars are tastier (plant-based vs petro-based insulation, apparently?) I basically keep snap traps set at all times, but the main thing has been to ensure there are no entry/exit openings and no easily accessible food or nesting materials to unnecessarily attract them from outside. |
volksaddict |
Jul 11 2024, 12:57 PM
Newbie Group: Members Posts: 23 Joined: 29-January 11 From: southwest Member No.: 12,645 Region Association: Southwest Region |
Pink insulation from the building the car is in. Usually it's the padding from the seats. I hate rodents!
bkrantz |
Jul 11 2024, 08:07 PM
I guess rodents are better behaved in Germany.
Front yard mechanic |
Jul 11 2024, 09:36 PM
Senior Member Group: Members Posts: 1,201 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I used the ozone generator to chase the little bastards out of a couple of cars. It depletes the oxygen and they leave or die. But you still have to clean up after them
dwillouby |
Jul 13 2024, 09:17 AM
Member Group: Members Posts: 394 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
technicalninja |
Jul 13 2024, 09:50 AM
I used the ozone generator to chase the little bastards out of a couple of cars. It depletes the oxygen and they leave or die. But you still have to clean up after them I looked into this! I'd never run across an ozone generator to remove critters from cars and thought "what a concept!" BE CAREFUL with this!!!!! Tons of threads on Reddit and other places regarding using these in automobiles. It seems the ozone can seriously jack with plastics causing them to out-gas like a MOFO! The biggest complaint was "unable to drive car due to the stench for weeks!" It seems the ozone generators work GREAT in a house to remove smells. Got a house that has been smoked in for decades? The ozone generator is the way to go! It just messes with plastic like nothing else I've ever run into. Due to the MASSIVE complaints regarding using these in cars I will not try it... |
bkrantz |
Jul 13 2024, 08:38 PM
Lo-Fi Version | Time is now: 16th September 2024 - 01:00 PM |
