1976 Windshield Wiper Switch, What Did I Do Wrong? |
Jim C |
Jul 11 2024, 06:34 AM
Member Group: Members Posts: 206 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region |
Recently on a rare occasion I was caught in the rain, I noticed that I did not have two speed wiper function. One click up started the wipers, but the second click up was no change in speed. I do not have the intermittent wipers option, at least there is no bracket and relay installed. The wiper switch seemed well used and since I also needed to replace the turn signal switch I figured to kill two birds. Both switches are installed, but now the wipers operate in the lowest (off) position, turn off in the middle (on) position, and remain off in the uppermost position so I still only one wiper speed. The replacement switch was supposedly for a 1975-1976 914. I can live with it since I do have wipers and never intentionally drive in the rain, but... (IMG:style_emoticons/default/WTF.gif)
dr914@autoatlanta.com |
Jul 11 2024, 09:35 AM
914 Guru Group: Members Posts: 8,043 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
probably have the pin sequence off
Recently on a rare occasion I was caught in the rain, I noticed that I did not have two speed wiper function. One click up started the wipers, but the second click up was no change in speed. I do not have the intermittent wipers option, at least there is no bracket and relay installed. The wiper switch seemed well used and since I also needed to replace the turn signal switch I figured to kill two birds. Both switches are installed, but now the wipers operate in the lowest (off) position, turn off in the middle (on) position, and remain off in the uppermost position so I still only one wiper speed. The replacement switch was supposedly for a 1975-1976 914. I can live with it since I do have wipers and never intentionally drive in the rain, but... (IMG:style_emoticons/default/WTF.gif) |
914Sixer |
Jul 11 2024, 11:25 AM
914 Guru Group: Members Posts: 8,986 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
As the good Dr said. Your off somewhere.
All the way down is intermittent 2nd is off 1up is slow 2up is fast |
Jim C |
Jul 11 2024, 12:09 PM
You mean where the switch plugs into the harness at the base of the steering column cover?
914Sixer |
Jul 11 2024, 07:34 PM
Yes
Jim C |
Jul 12 2024, 06:54 AM
Checked and rechecked and all five pins seated.
Steve |
Jul 12 2024, 07:53 AM
914 Guru Group: Members Posts: 5,678 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
76-914 |
Jul 12 2024, 08:24 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,608 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Jim, I have both the OEM used and OEM replacement switches that I can take pic's of if you need to check the wiring of your switch.
Jim C |
Jul 12 2024, 09:46 AM
76-914 |
Jul 14 2024, 05:41 PM
76-914 |
Jul 14 2024, 05:42 PM
76-914 |
Jul 14 2024, 05:43 PM
76-914 |
Jul 14 2024, 05:44 PM
Jim C |
Jul 15 2024, 07:30 AM
Lo-Fi Version | Time is now: 16th September 2024 - 12:51 PM |
