914-6 hand throttle accelerator pivot |
BillJ |
Jul 11 2024, 10:28 PM
Senior Member Group: Members Posts: 1,167 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Does anyone have or make an already assembled pivot for the pedal cluster side of the hand throttle? I know that the kit includes a little fin, but would prefer it already done and can install in my nice stone rebuilt cluster.
burton73 |
Jul 11 2024, 10:33 PM
burton73 Group: Members Posts: 3,646 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Did you Ck 914 Rubber. I think I was something from them for conversions
Bet Bob B |
BillJ |
Jul 11 2024, 10:37 PM
Their kit has a fin you can weld on to the throttle pivot. I want one that is already done
mb911 |
Jul 12 2024, 10:13 AM
914 Guru Group: Members Posts: 7,149 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
BillJ |
Jul 12 2024, 10:21 AM
Boy Ben, was just hoping you would say "sure will whip that right up and send to you man!" Lol
930cabman |
Jul 12 2024, 12:13 PM
Advanced Member Group: Members Posts: 3,511 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I have done 2 of these and modified both. I was lucky to have found a used original linkage with the "tab", so I was able to use it as a pattern. But IIRC there was a couple changes I had to make to get things right. Add to this, subtract from that, but cannot recall exactly
I also cut a section of the top portion of the tunnel away for easy access |
bdstone914 |
Jul 12 2024, 02:22 PM
bdstone914 Group: Members Posts: 4,657 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Does anyone have or make an already assembled pivot for the pedal cluster side of the hand throttle? I know that the kit includes a little fin, but would prefer it already done and can install in my nice stone rebuilt cluster. @billJ I can make one for you. I do it a little different in that i drill a hole in the accelerator crank and mount the fin with a 4mm screw. I use an original to get the orientation of the fin. Pretty busy but i can get one made in a couple weeks max. |
bdstone914 |
Jul 12 2024, 02:23 PM
Double post
BillJ |
Jul 12 2024, 02:26 PM
Does anyone have or make an already assembled pivot for the pedal cluster side of the hand throttle? I know that the kit includes a little fin, but would prefer it already done and can install in my nice stone rebuilt cluster. @billJ I can make one for you. I do it a little different in that i drill a hole in the accelerator crank and mount the fin with a 4mm screw. I use an original to get the orientation of the fin. Pretty busy but i can get one made in a couple weeks max. Awesome. Will PM you for details on where to send and to pay you. Seems only right as it is going into your cluster. |
Shivers |
Jul 13 2024, 08:07 AM
Senior Member Group: Members Posts: 2,646 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Does anyone have or make an already assembled pivot for the pedal cluster side of the hand throttle? I know that the kit includes a little fin, but would prefer it already done and can install in my nice stone rebuilt cluster. @billJ I can make one for you. I do it a little different in that i drill a hole in the accelerator crank and mount the fin with a 4mm screw. I use an original to get the orientation of the fin. Pretty busy but i can get one made in a couple weeks max. Any chance you could post a couple pics of the original? I have to make mine, thanks |
Lo-Fi Version | Time is now: 16th September 2024 - 12:59 PM |
