I feel like I need stickers on my air filter housing? |
mb911 |
Jul 12 2024, 05:45 AM
914 Guru Group: Members Posts: 7,149 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Superhawk996 |
Jul 12 2024, 07:42 AM
914 Guru Group: Members Posts: 6,464 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
K&N always has some good looking stickers (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/stirthepot.gif)
(IMG:style_emoticons/default/hide.gif) (IMG:style_emoticons/default/av-943.gif) |
Cairo94507 |
Jul 12 2024, 07:45 AM
Michael Group: Members Posts: 10,001 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I would love to see that filter housing top in satin black and then maybe add a period correct oil decal if you believe it still needs it. (IMG:style_emoticons/default/beerchug.gif)
mb911 |
Jul 12 2024, 08:42 AM
I would love to see that filter housing top in satin black and then maybe add a period correct oil decal if you believe it still needs it. (IMG:style_emoticons/default/beerchug.gif) Yup might get a satin clear on it. It’s powdered by my buddy thick to hide imperfections now gotta wet sand it then satin clear. Where does the oil sticker go? |
mb911 |
Jul 12 2024, 08:43 AM
K&N always has some good looking stickers (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/hide.gif) (IMG:style_emoticons/default/av-943.gif) Was thinking the snorkel would be prime for a turbo charge pipe with a low boost t3/t4 turbo. Well tuned like 10 hp per lb of boost? |
Jamie |
Jul 12 2024, 09:27 AM
Senior Member Group: Members Posts: 1,052 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I think I need to add some Porsche specific decals on the filter housing. What do you think? The housing is modified to fit and want to break up the look a little. Thoughts? You don't need no stinkin' stickers! (IMG:style_emoticons/default/bs.gif) |
Superhawk996 |
Jul 12 2024, 09:59 AM
K&N always has some good looking stickers (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/hide.gif) (IMG:style_emoticons/default/av-943.gif) Was thinking the snorkel would be prime for a turbo charge pipe with a low boost t3/t4 turbo. Well tuned like 10 hp per lb of boost? K&N sticker alone adds 10 hp, we’ll call it 20 hp with a charge pipe (IMG:style_emoticons/default/beerchug.gif) Wait . . . . I can’t tell are you being serious about the turbo ? (IMG:style_emoticons/default/unsure.gif) |
BillJ |
Jul 12 2024, 10:04 AM
Senior Member Group: Members Posts: 1,167 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
As an aside, been doing research on filtration and K&N does not fare all that well against their competitors in terms of flow. Better than stock yes but overall one of the most restrictive.
Here is a possible period correct application: https://www.early911sregistry.org/forums/sh...r-Cleaner-Decal |
mb911 |
Jul 12 2024, 10:16 AM
As an aside, been doing research on filtration and K&N does not fare all that well against their competitors in terms of flow. Better than stock yes but overall one of the most restrictive. Here is a possible period correct application: https://www.early911sregistry.org/forums/sh...r-Cleaner-Decal So it’s kind of an inside joke between Phil and I on the k&n thing. Gosh 25 plus years ago we did testing for an engine manufacturer between cotton/oiled k&n vs paper and the results of internal wear between the 2. K&n engines wore out considerably faster than a paper element |
mb911 |
Jul 12 2024, 10:17 AM
K&N always has some good looking stickers (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/hide.gif) (IMG:style_emoticons/default/av-943.gif) Was thinking the snorkel would be prime for a turbo charge pipe with a low boost t3/t4 turbo. Well tuned like 10 hp per lb of boost? K&N sticker alone adds 10 hp, we’ll call it 20 hp with a charge pipe (IMG:style_emoticons/default/beerchug.gif) Wait . . . . I can’t tell are you being serious about the turbo ? (IMG:style_emoticons/default/unsure.gif) Umm well it’s been in the back of my mind for a while. Now that my EFI is working pretty well and I am working through the tuning process it would be very easy |
Superhawk996 |
Jul 12 2024, 10:22 AM
K&N always has some good looking stickers (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/hide.gif) (IMG:style_emoticons/default/av-943.gif) Was thinking the snorkel would be prime for a turbo charge pipe with a low boost t3/t4 turbo. Well tuned like 10 hp per lb of boost? K&N sticker alone adds 10 hp, we’ll call it 20 hp with a charge pipe (IMG:style_emoticons/default/beerchug.gif) Wait . . . . I can’t tell are you being serious about the turbo ? (IMG:style_emoticons/default/unsure.gif) Umm well it’s been in the back of my mind for a while. Now that my EFI is working pretty well and I am working through the tuning process it would be very easy (IMG:style_emoticons/default/popcorn[1].gif) I’ll be watching and learning |
Root_Werks |
Jul 12 2024, 02:57 PM
Village Idiot Group: Members Posts: 8,414 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Stickers - easy to install, hard to remove.
rgalla9146 |
Jul 12 2024, 05:49 PM
Advanced Member Group: Members Posts: 4,618 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
OEM ?
Attached thumbnail(s) |
mb911 |
Jul 12 2024, 06:24 PM
Cairo94507 |
Jul 12 2024, 06:39 PM
I believe that is a factory placed sticker. (IMG:style_emoticons/default/beerchug.gif)
914Wes |
Jul 12 2024, 07:19 PM
Newbie Group: Members Posts: 3 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California |
https://shop.early911sregistry.org/products...duction-sticker
Early S registry sells a reproduction for $12 |
rgalla9146 |
Jul 12 2024, 08:57 PM
https://shop.early911sregistry.org/products...duction-sticker Early S registry sells a reproduction for $12 I agree, OEM on early 70s MFI 911s It may also be found on Euro delivery 914 6s It came to me on a 914 6 housing at a swap meet thirty years ago. It is turned ninety degrees on a 6 (compared to a 911) to be seen from the drivers side... where the oil goes in (IMG:style_emoticons/default/smile.gif) |
BillJ |
Jul 12 2024, 09:01 PM
I like that better than the 911 location
ClayPerrine |
Jul 12 2024, 09:36 PM
Life's been good to me so far..... Group: Admin Posts: 15,803 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Why is there a dent in the back of the air cleaner?????
mb911 |
Jul 13 2024, 04:46 AM
Why is there a dent in the back of the air cleaner????? Only way it would fit so had to massage it. Spent a ton of time on this. I have the engine at stock 914-6 height but the air cleaner just was a PIA but I refused to go with k&n setups. I purchased a few housings but all from 911s and required modifications before the engine lid bracing would clear |
Lo-Fi Version | Time is now: 16th September 2024 - 12:58 PM |
