> Strut location, Q
mwizard1
post Jul 12 2024, 09:08 AM
I think I saw somewhere that the lower mount for the front strut could be moved to improve handling. Any info on this?
Replies(1 - 9)
brant
post Jul 12 2024, 01:23 PM
QUOTE(mwizard1 @ Jul 12 2024, 09:08 AM) *
It’s for bump steer purposes
That only comes into play if a car is lowered so much that the stock geometry of the suspension is compromised by lowering the car
The modification is to correct the compromise of lowering
By changing the steering arm
On the bottom of the strut I’m less aware of modifications that would move or change
Some use offset ball joints when trying to increase negative camber
There are other things that can be done
My strut housing were sectioned. And with custom race Kori’s that are shorter than stock to give back shock travel on a lowered car
Get a performance oriented 4 wheel alignment with tires that are soft. Like 100 treadwear rated. And high end brake pads. You’ll enjoy that for a performance handling
mwizard1
post Jul 13 2024, 08:41 AM
QUOTE(brant @ Jul 12 2024, 12:23 PM) *
I am building an autocross car so I will be lowering it a lot. Where can I get more info or parts?
brant
post Jul 13 2024, 08:51 AM
The steering arm modification is usually done by a shop
It’s the same as what 911 guys do
The steering arm is heated and bent
Then cooled in vermiculite over a 3-5 day period
Another option is to buy a bump steer kit that mounts where the tie rod mounts go
stownsen914
post Jul 13 2024, 09:10 AM
OP may be thinking of raising the spindles on the strut. Depending on your setup, this can help keep the suspension geometry in a favorable range on a very lowered car. Brant may be referring to this in writing about a sectioned strut. The amount to raise the spindle depends how lowered the car is and how large in diameter your wheel/tire are. The modification is usually done by a shop set up to do the work.
post Jul 13 2024, 09:21 AM
914-6 GT in waiting
First learn about suspension setup or get an informed overview from someone who knows what they are doing. Then decide what you want to accomplish and how you plan to do it. Then buy parts, make modifications, etc.
Just doing random things to your car because you heard it might be better is like traveling without a map or destination.
technicalninja
post Jul 13 2024, 11:06 AM
QUOTE(mepstein @ Jul 13 2024, 10:21 AM) *
Start with small changes first!
Learn how to tune what you have...
The 914 has a WONDERFUL front upper mount that allows easy suspension adjustments on the fly.
First get used to what you already have the ability to do.
The lower mount would be one of the last things I'd mess with while learning how to tune my suspension.
Now, one mod I have bought already installed in a set of 911 A-arms is this set up.
https://www.elephantracing.com/porsche/914/...914/polybronze/
And these
https://www.elephantracing.com/porsche/914/...trol-arm-mounts
Those self-centering mounts do allow some suspension adjustment. It has to do more with how braking effects the front suspension (you can alter the "anti-dive response") but the changes you can achieve with these are MINOR IMO.
Now, I'm also planning on using an adjustable front sway bar and that is a GOOD mod IMO...
Like this.
https://tarett.com/products/front-swaybar-a...AiABEgKpRvD_BwE
That will change the "feel" more than anything else...
mwizard1
post Jul 16 2024, 08:55 AM
Thanks for the info.
Charles Freeborn
post Jul 16 2024, 09:03 AM
Elephant Racing and Tarett are both solid sources for info and parts.
Krieger
post Jul 20 2024, 10:40 PM
Tangerine Racing can raise your spindles on the strut and recurve the steering knuckle.
26 User(s) are reading this topic (26 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 2nd April 2025 - 02:37 AM
