Tarett Rear Monoball Shock Mount |
yeahmag |
Jul 15 2024, 03:12 PM
Advanced Member Group: Members Posts: 2,432 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Has anyone installed this? A friend gifted them to me and I want to make sure I have it right. It looks to me like the nut would replace the upper bushing and washer and the body would replace the lower bushing.
Montreal914 |
Jul 15 2024, 03:29 PM
Senior Member Group: Members Posts: 1,671 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
You have nice friends! (IMG:style_emoticons/default/smile.gif)
(IMG:style_emoticons/default/popcorn[1].gif) |
bdstone914 |
Jul 15 2024, 04:58 PM
bdstone914 Group: Members Posts: 4,657 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Has anyone installed this? A friend gifted them to me and I want to make sure I have it right. It looks to me like the nut would replace the upper bushing and washer and the body would replace the lower bushing. I would g lo on there website and see if they have an instruction sheet. Or call them. |
Shivers |
Jul 15 2024, 05:01 PM
Senior Member Group: Members Posts: 2,646 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Has anyone installed this? A friend gifted them to me and I want to make sure I have it right. It looks to me like the nut would replace the upper bushing and washer and the body would replace the lower bushing. I could not find any other pictures or an install video. If you have them in hand, is the body, where it splits is it flush to the other half or is there a partial gap so it could sandwich the sheet metal? Seems like an awful lot to stack on top of the shock |
BillJ |
Jul 15 2024, 05:39 PM
Senior Member Group: Members Posts: 1,167 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
I just dropped mine off with the shop Friday. I am of no help but are you going to also do the through bolt bushing at the same time? I am.doing the race bushings as well to make sure they are of equalish stiffness.
Call.Tarret. don't be shy. |
bkrantz |
Jul 15 2024, 07:52 PM
914 Guru Group: Members Posts: 8,042 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Has anyone installed this? A friend gifted them to me and I want to make sure I have it right. It looks to me like the nut would replace the upper bushing and washer and the body would replace the lower bushing. For a dedicated track/race car? Those will sure make the rear of the car "solid". |
stownsen914 |
Jul 16 2024, 07:55 PM
Senior Member Group: Members Posts: 928 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Pretty sure your assumption is correct. Nut on the top side.
yeahmag |
Jul 18 2024, 01:46 PM
From Tarett:
The large nut sits on top and sandwiches the chassis against the mount. We don’t have a specific spec on that nut and it is a bit hard to hold the mount once it is in the shock tower. An impact is the easiest way to get it tightened. |
Lo-Fi Version | Time is now: 16th September 2024 - 01:21 PM |
