> CV Joint flange bolts
914_3.0
post Jul 17 2024, 03:43 PM
Hello All,
I've got a 3.0 six conversion that has a 901 in it. I'm uncertain what approach was used for the five lug conversion. I found one bolt snapped off on the passenger side, and when I removed it found that the tip was still in the flange. The broken bolt also appears to be a course thread.
Two questions:
1) Is the flange supposed to be fine or course thread? I'm thinking that the correct hardware is an M8 x 45, with fine thread.
2) I can't see the part numbers on the flange because I don't have a lift, and the cast numbers are on the transaxle side. Any other ways to identify the approach that was used for the five lug conversion quickly? (914, 911, 944).
Thanks for any help!
Todd
Replies(1 - 3)
bdstone914
post Jul 17 2024, 05:14 PM
bdstone914
The CV's do not need to be changed for a 5 lug conversion. Looks like you still have the 914 CV's and bolts. You may need to remove the output flange from the trans to remove the broken bolt. There is one bolt in the center of the flange butied under the grease. I think it had a 15mm head.
I would replace all the bolts on tgat cv and re-torque all the others.
bkrantz
post Jul 17 2024, 07:10 PM
Make sure the roll pins are in place, since they carry most of the torque.
914_3.0
post Jul 18 2024, 09:00 AM
Thank you for the info and suggestions, gentlemen!
- Lo-Fi Version Time is now: 16th September 2024 - 12:54 PM
