even I can learn something new about a 914, trunk hinge rod bracket |
dr914@autoatlanta.com |
Jul 18 2024, 01:04 PM
914 Guru Group: Members Posts: 8,043 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Jul 18 2024, 01:05 PM
Root_Werks |
Jul 18 2024, 01:45 PM
Village Idiot Group: Members Posts: 8,414 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Probably saved a few bucks in production. I know my 75' doesn't have it.
Interesting indeed! |
East coaster |
Jul 18 2024, 02:20 PM
Senior Member Group: Members Posts: 1,748 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
One less rattle (IMG:style_emoticons/default/wink.gif)
Jack Standz |
Jul 18 2024, 03:00 PM
Member Group: Members Posts: 361 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
On a somewhat related note. If you no longer have a rear trunk release button and use only a cable release, then the cable breaks. Can you take the hinges off so you can get to the latch with a set of extensions to remove the bolts so you can remove the trunk lid and fix the problem? Asking for a friend.
We've done this before a long time ago by pushing in one of the plastic cups and using a bunch of extensions. It seems like it might be easier to take the fasteners off the hinges and then hold the front part of the trunk lid open to get at the latch. Ideas? |
rick 918-S |
Jul 18 2024, 03:28 PM
Hey nice rack! -Celette Group: Members Posts: 20,667 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
On a somewhat related note. If you no longer have a rear trunk release button and use only a cable release, then the cable breaks. Can you take the hinges off so you can get to the latch with a set of extensions to remove the bolts so you can remove the trunk lid and fix the problem? Asking for a friend. We've done this before a long time ago by pushing in one of the plastic cups and using a bunch of extensions. It seems like it might be easier to take the fasteners off the hinges and then hold the front part of the trunk lid open to get at the latch. Ideas? Yup done it |
wonkipop |
Jul 18 2024, 05:57 PM
Advanced Member Group: Members Posts: 4,594 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Always thought that all year 914s had a loop for the trunk hinge rods, but just saw that the 74-76 cars do not!!! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) and i would have thought all of em didn't have a loop like mine. its a jan 74. but i don't get to look at many 914s down here in north antarctica. could it have something to do with shifting the charcoal cannister into the engine bay? do the rods adopt a slightly different position without the loop? asking because if that is the case maybe the changeover is when they move the can from the frunk which is in nov 73. mindless minutia asked by an L jet nutter. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
bkrantz |
Jul 18 2024, 07:13 PM
914 Guru Group: Members Posts: 8,042 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Maybe the guys on the assembly line got better at installing the torsion bars, and stopped worrying about getting hit in the face. (IMG:style_emoticons/default/beer.gif)
r_towle |
Jul 18 2024, 07:23 PM
Custom Member Group: Members Posts: 24,620 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Now I need to go look at my 75/6
wonkipop |
Jul 18 2024, 07:39 PM
@dr914@autoatlanta.com
is it just my imagination? or did they also change the latch reinforcement pressing from 73 to 74. minutia. (IMG:style_emoticons/default/biggrin.gif) i just checked my jan 74 build 1.8 and the reinforcement panel does not have the compound curve in it like the 73 (left side image) - mine matches the 74 one in right side image. discount my previous thought re charcoal can. the 74 in image above is pre nov 73 build. but are they doing something with hood reinforcement panel rod clearance modification? |
JamesM |
Jul 18 2024, 11:11 PM
Senior Member Group: Members Posts: 1,958 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
thomasotten |
Jul 19 2024, 01:34 AM
Senior Member Group: Members Posts: 1,552 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
George,
I think the real question is how are you able to have a shop with such nice tile floors? I would think they would be easy to crack or the grout get stained. |
930cabman |
Jul 21 2024, 08:04 AM
Advanced Member Group: Members Posts: 3,511 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Just goes to show you, we never stop learning, ever
Lo-Fi Version | Time is now: 16th September 2024 - 12:53 PM |
