D jet question, Is this a stock part? |
Flyinlow |
Jul 21 2024, 11:09 AM
Flyinlow Group: Members Posts: 54 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada |
This wye fitting was on my bastardized dapo fuel line return…. firstly is it a stock part? Second can I use a tee in it’s place without an adverse effect?
Attached thumbnail(s) |
Superhawk996 |
Jul 21 2024, 11:45 AM
914 Guru Group: Members Posts: 6,464 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Return fuel line “y”
I personally would not run that. Replace it with a metal fitting. Too many fuel related engine fires and vehicles lost each year. A “y” will flow better than a “t” but it isn’t going to be noticeable in a return line flowing back to the tank. The “y” will probably route the line more suitably too depending on how you’re set up. |
JeffBowlsby |
Jul 21 2024, 12:01 PM
914 Wiring Harnesses Group: Members Posts: 8,654 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Factory Y. Never known these to fail, but do what you want.
Flyinlow |
Jul 21 2024, 01:09 PM
Return fuel line “y” I personally would not run that. Replace it with a metal fitting. Too many fuel related engine fires and vehicles lost each year. A “y” will flow better than a “t” but it isn’t going to be noticeable in a return line flowing back to the tank. The “y” will probably route the line more suitably too depending on how you’re set up. Thanks |
Flyinlow |
Jul 21 2024, 01:10 PM
Lo-Fi Version | Time is now: 16th September 2024 - 01:06 PM |
