Parts |
Parts |
B2524 |
Jul 23 2024, 11:59 AM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
Various parts:
Lot 1: PMB rebuilt front calipers, painted blue, never had fluid in them, I’m going to a 911 front suspension set, don’t need these. New pads and used hardware included. $250/pr. Lot 2: new cross drilled front rotors never used surface rust from sitting on a car, new bearings and used caps, going 911, don’t need these. $100/pr. Lot 3: everything else in the photo. Only one sway bar arm, only one headlight surround, nice plating on the latches and catch, wiring boot is soft, 2.0 Fuchs caps need a crest glued to the center to hide the dents otherwise nice. Front A arm bushing kit is new and includes install tool. Sold SOld SOLd SLOD! Shipping is extra on all lots, local pickup is preferred. Attached thumbnail(s) |
bdstone914 |
Jul 23 2024, 09:48 PM
bdstone914 Group: Members Posts: 4,657 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Looks like the calipers are early style. I assume the rotors are also early. I dont need them but an interested buyer will need to know.
I will take the group three parts. I do not need the white headlight surround. I woyld need them shipped to Riverside. If you pack them and provide the dimensions and weight i can email a shipping label. |
B2524 |
Jul 23 2024, 09:56 PM
Thanks Bruce. I am tied up until next week so it will be Tuesday before I can get the info to you.
Literati914 |
Jul 23 2024, 10:19 PM
Senior Member Group: Members Posts: 1,651 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Looks like the calipers are early style. I assume the rotors are also early. I dont need them but an interested buyer will need to know. That caliper(s..?) looks to have two bleeder screws, so that makes 'em late model, no? Also, doesn't that caliper have a spacer - to accommodate vented rotors (may just be the pic)? ..then, there's the banjo bolt (IMG:style_emoticons/default/confused24.gif) |
B2524 |
Jul 26 2024, 10:59 AM
No spacer non vented caliper.
Note the new pads and PMB plating still showing. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 16th September 2024 - 12:59 PM |
