TonyA |
Nachmal ![]() ![]() ![]() Group: Members Posts: 588 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States ![]() ![]() |
Pet catalog states rocker panel screws are to be phillips oval head screws. I have never seen a car with those screws attaching the rocker panels. BUT AA parts catalogue does state phillips oval head screws as the correct screw but the kit to install the rocker panels come with pan head screws, as I have always seen on other cars. So to be officially correct is it pan head or oval? Zinc or cad plated? Don't you just love my question?
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,870 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Which screws?
Black plastic round head rivets for your 74. Hex machine screws, nuts, washers and rubber spacers are needed at the ends. M6 (or is it M8?) screws/washers for bottom of panel to chassis. AA should have everything needed. |
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,109 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
I think (?) Tony means the three screws that go on the bottom edge of the panels.
Yes, the Phillip head screws are correct but are often hard to remove. Switched to anodized hex lag screws several decades ago; no problem removing/reinstalling. |
Lo-Fi Version | Time is now: 2nd April 2025 - 02:39 AM |
