> Turn Signal wiring?
torakki
post Aug 30 2024, 02:14 PM
On the '74 2.0L, the turn signals are a bit wacky. I know that the same relay for the parking brake is used. Issue: The parking brake light, in the instrument cluster, is always flashing. Until recently, it only flashed with the parking brake on. Now, flashes all the time. I bought a new relay, thinking the one I was using wasn't correct for the car but no change. So why is the turn signal relay, flashing the parking brake warning light? Also, the blinkers work but the green light in the instrument cluster doesn't flash.
Something simple?
Thanks for any input...
Replies(1 - 3)
davep
post Aug 31 2024, 03:45 PM
914 Historian
Okay, to start this off, you have a flasher relay that makes lights blink. How the output is directed is determined by the turn signal switches, various warning circuits, and the Hazard switch. Sounds like your wiring is screwed up.
Spoke
post Aug 31 2024, 04:25 PM
Jerry
@torakki
The ebrake and the brake MC warning switches both will light up the brake warning light in the dash. The MC warning switch might have a reset button. See if it does and press it. If that doesn't work, try disconnecting the wires on the MC warning switch.
About the tach indicator, I assume you have the single L/R indicator as normal in the '74 model year.
Did the old relay flash the indicator?
Do you have incandescent bulbs for turnsignals or LEDs?
Does the L/R indicator flash with 4-ways on?
Does the L/R indicator flash with just the right side on?
Does the L/R indicator flash with just the left side on?
torakki
post Sep 4 2024, 02:05 PM
Sorry for late reply. I don't get notifications.
Spoke maybe on to something. I had carbs installed recently and the shop that did it was tracing a fuel leak, under the cover for the MC area. Maybe something got bumped/pulled. I also put new front pads on. That would be a good place to start.
Yes, I do have the single L/R indicator with incandescent bulbs. And both old and new relays flash the ebrake indicator.
The L/R light does not flash with anything. 4 ways work, ebrake light flashed, all 4 corners of the car flash but no green light. Bulb appears to be good.
I'll try the MC reset button. I did this before on one of our cars. Probably in a few days. It's 100+ in our area,
Thanks for the comments and info. Updates, when it cools off.
- Lo-Fi Version Time is now: 22nd December 2024 - 04:57 AM
