Puck for the horn, want dimensions |
worn |
Sep 2 2024, 10:28 AM
can't remember Group: Members Posts: 3,376 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Hi all y'all,
I am getting tired of having my horn go off at inopportune moments because I have nudged the butterfly on the steering wheel by mistake. Ahh, a smooth sharp left turn with great savor faire an... blaaaaahhhhhhhhhhhhh, dammit. So I want to be a cool kid and have a puck button. But not at that price! (insert eye watering emoji) And of course I make everything myself anyway. So could someone give me the OD and ID and height in and out? I can work it out from there. Might go with aluminum but also might go with ebony or rosewood from scraps that I have. Thanks so much. If necessary, I can bring calipers to RRC, but online would be better. That way I won't lose the scrap of paper I have them written on. I know that there is a 3D printer file but I don't think that I could unravel it to get the measurements. Thanks so much. Warren |
mepstein |
Sep 2 2024, 10:49 AM
914-6 GT in waiting Group: Members Posts: 19,669 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
4” ID at the base. The top tapers in a bit so about 3 1/2 where the chrome ring sits.
emerygt350 |
Sep 2 2024, 12:33 PM
Advanced Member Group: Members Posts: 2,523 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I had to make up my dimensions on that file anyway. I have been meaning to go back and massage it a little, try to replicate some of the details like the ring etc... Is that decreasing diameter linear or just in a portion of the puck?
That said, I no longer accidently hit my horn. And I can see my dash better, although the fog lights button is a little bright. |
worn |
Sep 2 2024, 02:54 PM
I had to make up my dimensions on that file anyway. I have been meaning to go back and massage it a little, try to replicate some of the details like the ring etc... Is that decreasing diameter linear or just in a portion of the puck? That said, I no longer accidently hit my horn. And I can see my dash better, although the fog lights button is a little bright. If you can get me the base OD and the inner ID that would be grand. The depth of the hole would help a lot too. Thanks folks for all the great help this time and lots of others. |
mepstein |
Sep 2 2024, 03:26 PM
I had to make up my dimensions on that file anyway. I have been meaning to go back and massage it a little, try to replicate some of the details like the ring etc... Is that decreasing diameter linear or just in a portion of the puck? That said, I no longer accidently hit my horn. And I can see my dash better, although the fog lights button is a little bright. If you can get me the base OD and the inner ID that would be grand. The depth of the hole would help a lot too. Thanks folks for all the great help this time and lots of others. You can get a lot of the dimensions from your batwing. |
emerygt350 |
Sep 2 2024, 05:35 PM
I can find the dimensions I used tomorrow morning. I can send you the cad file but you probably don't need all that.
worn |
Sep 2 2024, 06:58 PM
[/quote] You can get a lot of the dimensions from your batwing. [/quote] I plan to do that, but would rather have some help as well. My experience with measure twice cut once has been hit and miss at times. |
porschetub |
Sep 2 2024, 07:56 PM
Advanced Member Group: Members Posts: 4,759 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
[quote name='worn' date='Sep 3 2024, 12:58 PM' post='3165217']
[/quote] You can get a lot of the dimensions from your batwing. [/quote] I plan to do that, but would rather have some help as well. My experience with measure twice cut once has been hit and miss at times. [/quote] I built one with 914 rubber plastic housing ,the biggest cost is the chrome trim ,found the leather insert @ a fair price , but really not that cheap but result was what I wanted ,cheers. |
worn |
Sep 2 2024, 09:01 PM
[quote name='porschetub' date='Sep 2 2024, 06:56 PM' post='3165232']
[quote name='worn' date='Sep 3 2024, 12:58 PM' post='3165217'] [/quote] You can get a lot of the dimensions from your batwing. [/quote] I plan to do that, but would rather have some help as well. My experience with measure twice cut once has been hit and miss at times. [/quote] I built one with 914 rubber plastic housing ,the biggest cost is the chrome trim ,found the leather insert @ a fair price , but really not that cheap but result was what I wanted ,cheers. [/quote] Nice work! Looks like 914 Rubber isn’t offering that part anymore. That is what I am aiming to make. Thanks. |
mepstein |
Sep 3 2024, 05:07 AM
[quote name='worn' date='Sep 2 2024, 11:01 PM' post='3165239']
[quote name='porschetub' date='Sep 2 2024, 06:56 PM' post='3165232'] [quote name='worn' date='Sep 3 2024, 12:58 PM' post='3165217'] [/quote] You can get a lot of the dimensions from your batwing. [/quote] I plan to do that, but would rather have some help as well. My experience with measure twice cut once has been hit and miss at times. [/quote] I built one with 914 rubber plastic housing ,the biggest cost is the chrome trim ,found the leather insert @ a fair price , but really not that cheap but result was what I wanted ,cheers. [/quote] Nice work! Looks like 914 Rubber isn’t offering that part anymore. That is what I am aiming to make. Thanks. [/quote] The 914rubber part wasn’t very good. |
ConeDodger |
Sep 3 2024, 05:28 AM
Apex killer! Group: Members Posts: 23,859 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Mine worked great! You had to treat it like an upholstery job. The leather insert doesn’t like being just placed in there with hopes it will stay.
Attached thumbnail(s) |
porschetub |
Sep 3 2024, 01:29 PM
[quote name='mepstein' date='Sep 3 2024, 11:07 PM' post='3165255']
[quote name='worn' date='Sep 2 2024, 11:01 PM' post='3165239'] [quote name='porschetub' date='Sep 2 2024, 06:56 PM' post='3165232'] [quote name='worn' date='Sep 3 2024, 12:58 PM' post='3165217'] [/quote] You can get a lot of the dimensions from your batwing. [/quote] I plan to do that, but would rather have some help as well. My experience with measure twice cut once has been hit and miss at times. [/quote] I built one with 914 rubber plastic housing ,the biggest cost is the chrome trim ,found the leather insert @ a fair price , but really not that cheap but result was what I wanted ,cheers. [/quote] Nice work! Looks like 914 Rubber isn’t offering that part anymore. That is what I am aiming to make. Thanks. [/quote] The 914rubber part wasn’t very good. [/quote] (IMG:style_emoticons/default/agree.gif) yes it wasn't great ,the one I got was strangely a grey/black colour so I repainted it satin black , it was also a bit out of shape but when clipped on seem to look better . After that pic was taken I packed out the leather with a piece of felt underneath and it improve the look more ,cheers. |
emerygt350 |
Sep 3 2024, 05:48 PM
mlindner |
Sep 3 2024, 05:54 PM
Senior Member Group: Members Posts: 1,594 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Hi Worn, Mark from Merrimac. I need a horn puck just to cover the steering shaft nut...No logo, no chrome, no horn. I'll buy one of your early prototypes. Mark
worn |
Sep 3 2024, 09:45 PM
emerygt350 |
Sep 4 2024, 09:56 AM
My dimensions at the base are 100mm OD 95mm ID and I have a 19mm depth cavity where I mount the metal base for the horn mechanism. The fit and clearances are all good.
sixnotfour |
Sep 4 2024, 10:48 AM
914 Wizard Group: Members Posts: 10,692 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
OG (IMG:style_emoticons/default/beerchug.gif) ,, Glad to have grown up in a Porsche rich area with a good ,Junkyard,,,
sent you a message.. Attached image(s) |
emerygt350 |
Sep 4 2024, 12:14 PM
nice. I am learning how to use lattice2 in freecad, that picture will really help recreate the ribs on the side of the puck.
emerygt350 |
Sep 4 2024, 12:55 PM
worn |
Sep 4 2024, 07:22 PM
Lo-Fi Version | Time is now: 2nd January 2025 - 07:11 AM |
