customer wants to know the month of his build, 4732920724 |
dr914@autoatlanta.com |
Sep 5 2024, 02:28 PM
914 Guru Group: Members Posts: 8,120 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
body shop lost his tags and the rear trunk floor has been replaced. Thought that there was somewhere on the site with numbers and build dates but could not find it
rhodyguy |
Sep 5 2024, 02:42 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,207 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
# on right inside side top of fender in frunk?
Root_Werks |
Sep 5 2024, 02:43 PM
Village Idiot Group: Members Posts: 8,539 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Root_Werks |
Sep 5 2024, 02:46 PM
4732920724
1973 29th Week 2 = Tuesday 0724 = Consecutive Chassis number Is that right? |
Sep 5 2024, 03:09 PM
no can only get it from the karmann number, this guy does not have his karmann number hence need to compare his id number to others in the world data base to get a range for the month produced
4732920724 1973 29th Week 2 = Tuesday 0724 = Consecutive Chassis number Is that right? |
SirAndy |
Sep 5 2024, 03:19 PM
Resident German Group: Admin Posts: 41,972 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
- Go here http://www.914world.com/bbs2/index.php?act...amp;byYear=1973
- Look for any VINs close to 4732920724 - Find VINs with either a "c" (Chassis Number) or "d" (Date Code) - See what range your VIN falls into (IMG:style_emoticons/default/bye1.gif) |
SirAndy |
Sep 5 2024, 03:23 PM
- Go here http://www.914world.com/bbs2/index.php?act...amp;byYear=1973 - Look for any VINs close to 4732920724 - Find VINs with either a "c" (Chassis Number) or "d" (Date Code) - See what range your VIN falls into (IMG:style_emoticons/default/bye1.gif) Closest previous VIN with a date code: 4732920632 04/73 Closest following VIN with a date code: 4732920782 - 05/73 - 1839593 @dr914@autoatlanta.com Since 4732920782 was the 93rd car made that day and 4732920724 is only 58 cars prior, it stands to reason both cars were made on the same day. (IMG:style_emoticons/default/popcorn[1].gif) |
SirAndy |
Sep 5 2024, 03:26 PM
4732920724 1973 29th Week 2 = Tuesday 0724 = Consecutive Chassis number Is that right? @Root_Werks No, you can't use the VIN, you need the chassis number, which the Dr. doesn't have. (IMG:style_emoticons/default/shades.gif) |
Root_Werks |
Sep 5 2024, 03:54 PM
4732920724 1973 29th Week 2 = Tuesday 0724 = Consecutive Chassis number Is that right? @Root_Werks No, you can't use the VIN, you need the chassis number, which the Dr. doesn't have. (IMG:style_emoticons/default/shades.gif) Ah, got it now, thanks! |
Sep 5 2024, 04:05 PM
thank you very much Andy
worn |
Sep 5 2024, 05:21 PM
Winner of the Utah Twisted Joint Award Group: Members Posts: 3,383 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
4732920724 1973 29th Week 2 = Tuesday 0724 = Consecutive Chassis number Is that right? @Root_Werks No, you can't use the VIN, you need the chassis number, which the Dr. doesn't have. (IMG:style_emoticons/default/shades.gif) Now that I have thrown away the ferric oxide foil trunk floor, where would the chassis number have been? |
Montreal914 |
Sep 5 2024, 05:39 PM
Senior Member Group: Members Posts: 1,742 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Cut out mine when I replaced my trunk floor and installed it in the new floor. (IMG:style_emoticons/default/smile.gif)
914Wes |
Sep 5 2024, 05:48 PM
Newbie Group: Members Posts: 15 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California |
Made a quick and simple chassis number decoder.
Porsche 914 chassis number decoder If anyone has any issues with it let me know and I can modify it. Appears to work correctly for my 1974 (IMG:style_emoticons/default/smile.gif) |
SirAndy |
Sep 5 2024, 05:49 PM
No, you can't use the VIN, you need the chassis number, which the Dr. doesn't have. (IMG:style_emoticons/default/shades.gif) Now that I have thrown away the ferric oxide foil trunk floor, where would the chassis number have been? @worn www.914world.com/bbs2/sources/action_public/pop_helpchassis.html (IMG:style_emoticons/default/bye1.gif) |
worn |
Sep 5 2024, 07:08 PM
No, you can't use the VIN, you need the chassis number, which the Dr. doesn't have. (IMG:style_emoticons/default/shades.gif) Now that I have thrown away the ferric oxide foil trunk floor, where would the chassis number have been? @worn www.914world.com/bbs2/sources/action_public/pop_helpchassis.html (IMG:style_emoticons/default/bye1.gif) Thanks Sir Andy. Yep, that is gone. Now I also have to deal with replacing the driver’s B-pillar label. Any suggestions? I have of course saved that piece. |
914_7T3 |
Sep 5 2024, 10:02 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,872 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
I thought the 29 is the Karmann Factory designation.
My Vin is 4732921258 and was manufactured May 19, 1973 per COA. Not sure how many cars were produced per day. |
sportlicherFahrer |
Sep 6 2024, 07:08 AM
Nothing to see here. Group: Members Posts: 1,111 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Thanks Sir Andy. Yep, that is gone. Now I also have to deal with replacing the driver’s B-pillar label. Any suggestions? I have of course saved that piece. @worn Punched Early VIN Label Punched Late VIN label Apparently Car-Bone is a possibility, per this thread. No recent updates: Door Jamb VIN Sticker Thread |
Root_Werks |
Sep 6 2024, 11:07 AM
Thanks Sir Andy. Yep, that is gone. Now I also have to deal with replacing the driver’s B-pillar label. Any suggestions? I have of course saved that piece. @worn Punched Early VIN Label Punched Late VIN label Apparently Car-Bone is a possibility, per this thread. No recent updates: Door Jamb VIN Sticker Thread I bought a Door jam sticker from CarBone and love it. Mine was toast anyway. My mistake was getting a black one instead of silver like it should be . Oh well, looks cool. |
Montreal914 |
Sep 7 2024, 09:16 AM
Made a quick and simple chassis number decoder. Porsche 914 chassis number decoder If anyone has any issues with it let me know and I can modify it. Appears to work correctly for my 1974 (IMG:style_emoticons/default/smile.gif) @914Wes Tried with my 1973 and didn't work. (IMG:style_emoticons/default/sad.gif) |
SirAndy |
Sep 7 2024, 10:37 AM
Made a quick and simple chassis number decoder. Porsche 914 chassis number decoder If anyone has any issues with it let me know and I can modify it. Appears to work correctly for my 1974 (IMG:style_emoticons/default/smile.gif) @914Wes Tried with my 1973 and didn't work. (IMG:style_emoticons/default/sad.gif) @914Wes Line 11 is incorrect. The 95 will roll over to a 96 if there were more than 99 cars made that day. So your daily_sequence should be computed as: CODE roll_over = int(chassis_number[3:5]) daily_sequence = int(chassis_number[5:7]) + ((roll_over - 95) * 100) (IMG:style_emoticons/default/type.gif) |
Lo-Fi Version | Time is now: 15th January 2025 - 04:00 AM |
