Hard hot starting solution…? |
oakdalecurtis |
Oct 8 2024, 03:08 PM
Oakdalecurtis Group: Members Posts: 1,346 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I know we’ve discussed this, but here’s the situation. 76 fuel injected with stock 2.0 other than Crane ignition, runs perfectly. I installed the 6v Ford relay on the starter a few years ago. Good Optima redtop battery. I have cleaned all the grounds at body and transmission. Still, after driving and shut off, it barely, if at all, turns over on immediate restarts. I thought I would just run a negative cable directly from the battery negative post to the starter to see if that helped. Questions:
Is that an appropriate possible fix? If so, what gauge cable (will make one up) should I use? Any thoughts on general optimal routing in the engine bay? Any other thought? Ty |
emerygt350 |
Oct 8 2024, 03:22 PM
Advanced Member Group: Members Posts: 2,511 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
oakdalecurtis |
Oct 8 2024, 07:58 PM
914werke |
Oct 8 2024, 08:22 PM
"I got blisters on me fingers" Group: Members Posts: 11,022 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
technicalninja |
Oct 8 2024, 08:37 PM
Advanced Member Group: Members Posts: 2,087 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I ran a neg cable from the battery post to the fan shroud, fixed all my ills. You may have a failing starter but I would try the neg cable first. I kept the post to body ground as well. And the transmission ground of course. I’ll try that, ty! I like simple first. What gauge wire? You can test if that is going to help with jumper cables. Don't have to purchase anything. Bigger is better for cables. Cheap 24" battery cable (FLAPS) will work fine. You can purchase them with eyelets on both ends... |
emerygt350 |
Oct 9 2024, 05:18 AM
Yep, that one is a starter cable from flaps for a lawn tractor. 4 gauge? 8 gauge? Can't remember.
davep |
Oct 9 2024, 07:18 AM
914 Historian Group: Benefactors Posts: 5,220 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
This was my solution 20 years ago and it worked. try 2 or 4 AWG; remember the starter amps will be over 200 for at least a moment.
r_towle |
Oct 9 2024, 06:53 PM
Custom Member Group: Members Posts: 24,656 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I might suggest the 50 year old starter needs lubrication..maybe a rebuild.
I ran a ground cable, 3 feet long, to the mounting bolt on the starter. |
rick 918-S |
Oct 9 2024, 08:14 PM
Hey nice rack! -Celette Group: Members Posts: 20,817 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I am not a believer in those Rubgoldberg devices. Try the Ed test. When the engine fails to start when hot, run a new set of jumper cables from the battery to the starter. Try to crank it. If you are still running 50 year old battery cables like me because they look new from the outside it is time to replace them.
oakdalecurtis |
Oct 10 2024, 01:36 PM
I ran a neg cable from the battery post to the fan shroud, fixed all my ills. You may have a failing starter but I would try the neg cable first. I kept the post to body ground as well. And the transmission ground of course. Emery wins! I installed a 4 gauge lead from battery negative to fan housing as you suggested. Starts hot now like never before! Thank you.... |
emerygt350 |
Oct 10 2024, 01:41 PM
excellent. Make sure you keep the body ground as well.
914werke |
Oct 10 2024, 06:04 PM
I am not a believer in those Rubgoldberg devices. (IMG:style_emoticons/default/unsure.gif) what are you talking about? (IMG:style_emoticons/default/confused24.gif) |
emerygt350 |
Oct 10 2024, 06:39 PM
I am not a believer in those Rubgoldberg devices. (IMG:style_emoticons/default/unsure.gif) what are you talking about? (IMG:style_emoticons/default/confused24.gif) I think it's the Ford solenoid he is referring to. |
Lo-Fi Version | Time is now: 22nd December 2024 - 05:41 AM |
