> Fuchs Center Caps, Center bore diameter
Mowog4
post Oct 12 2024, 01:13 PM
Hi, I am ordering a set of custom wheels and want to use A factory center cap. Anyone have an idea of what the center for the wheel should be.
Thanks, Ed
Replies(1 - 12)
Mikey914
post Oct 12 2024, 07:04 PM
The rubber man
What do you need ? I have sone variations I made.
May have what you need.
Mark
Mowog4
post Oct 12 2024, 08:52 PM
QUOTE(Mikey914 @ Oct 12 2024, 06:04 PM) *
Mark
Hey Mark
I am looking for aluminum Porsche center caps that came on the Fuchs wheels. I am having a set of wheels manufacturer for me in Europe, I’m trying to figure out what size to bore the center hole so I can polish and use original center cups.
technicalninja
post Oct 12 2024, 09:31 PM
60mm is what I measure on both a set of real Fuch 4 lug and clone copy 5 lugs.
There may be differences I'm not aware of.
Mowog4
post Oct 13 2024, 04:09 AM
QUOTE(technicalninja @ Oct 12 2024, 08:31 PM) *
Thanks, that helps
brant
post Oct 13 2024, 09:20 AM
4 or 5 bolt Fuchs?
There are two different sizes of 5 bolt center caps. (Early and late)
rgalla9146
post Oct 13 2024, 09:24 AM
sorry, couldn't find my metric ruler quickly ...in a time pinch
rgalla9146
post Oct 13 2024, 09:26 AM
and the other
Mowog4
post Oct 13 2024, 10:40 PM
QUOTE(rgalla9146 @ Oct 13 2024, 08:26 AM) *
and the other
Thank you so much, this is great. I think I will go for the larger diameter since I’m going to run a larger wheel. Thanks for the effort.
technicalninja
post Oct 13 2024, 11:01 PM
QUOTE(Mowog4 @ Oct 13 2024, 11:40 PM) *
and the other
Don't choose that way...
If you have the ability to order what you want, I'd order the more popular size in caps.
You also should check with your wheel manufacture, if one of the sizes is "standard"
changing size might create an upcharge.
I would want to "see" both sizes so a bit of image manipulation might be worth it.
One of the sizes (smaller) also fits 4 lug caps which are different than 911.
I have a question as well. @brant
What denotes early vs late for 911 wheels?
brant
post Oct 14 2024, 07:30 AM
Somewhere around 70-71 I believe
Used to know
Would have to do a little research
Old caps were 3 prong as pictured above
Mikey914
post Oct 14 2024, 05:01 PM
The rubber man
Sorry, the caps I made were for the 4 lug Fuchs.
chmillman
post Oct 15 2024, 10:05 AM
Region Association: Europe
Put new tires on my 7x15 Fuchs today, measured the cap lip inside, it was 71mm.
- Lo-Fi Version Time is now: 21st December 2024 - 07:28 PM
